Go Back   Automotive Forums .com Car Chat > Ford > Aerostar
Old 03-04-2009, 04:20 PM   #1
billa63
Exclamation 93 Aerostar, no Headlights
my headlights won't work this morning, everything else seems to... even the running lights
I pulled every 25 and 30 amp fuse and found 1 bad, but lights still have no power, are there 2nd fuses/links under hood and if so where?
billa63 is offline   Reply With Quote
Old 03-04-2009, 08:12 PM   #2
rhandwor
Re: 93 Aerostar, no Headlights
Look at the starter for a burned fuse able link. You can use a DVOM and make sure the headlight switch and ignition switch are good.
rhandwor is offline   Reply With Quote
Old 03-08-2009, 07:10 PM   #3
billa63
Cool Re: 93 Aerostar, no Headlights
Just a follow-up, Fusible links were good.
Checked power and other points and found that sockets had power but one was singed at ground wire. Secured better grounding and lights now work!
Tags
areostar , ford , fuse , headlight
