1994 Explorer Eddie Bauer Remote Reprogramming
I just bought a 1994 Explorer Eddie Bauer for my son. The remote was missing, but I bought a replacement. The instructions for reprogramming say to "momentarily jump the pins in the programming connector in the LR qtr panel". I can't fint this programming connector. Where should I look, and what will it look like? Or - are these the correct instructions?
OK here is the deal it is very easy and takes about 5 minutes. open the jack compartment in the drivers rear. in the compartment you will have a black box with 3 harnesses plugged in it, it is the box you need. Unlock all the doors and turn the key to ACC ( where the panel lights up but truck is not started) have all remotes in your hand take a paper clip and bend it in a U for a jumper. the wires you want to jump are on the lower connector of the 3 should be a black harness. the wires to jump are the rearmost wires on top and bottom of the single connector. this will "cycle" the locks closed and open leave the jumper in take your remote and press lock the locks should lock.the remote is programmed press lock on the second remote if you have one. turn the key off and remove it now remove the jumper" paper clip" and you are good to go.
