Go Back   Automotive Forums .com Car Chat > Hyundai > Tiburon | Tuscani
Old 09-07-2005, 05:23 PM   #1
JennyTib
Unhappy 2000 Tiburon Check Engine light on again!!!!
I've owned my Tiburon since 2000. I've had almost no problems with it. About 2 years ago the check engine light came on and then about 1 minute later the engine died in the middle of town. I had to have it towed in. The problem----needed new plugs, wires & the fuel system was cleaned. About 6 months ago the check engine light came on at home so I didn't go anywhere. My husband changed the plugs & wires, it sounded good so I drove it to Hyundai and they said the code was the plugs. They also changed the manifold gasket that was recalled while they had it.
OK, yesterday the check engine light came on while I was driving and again I was stranded in town. It was towed home. My hubby thinks we should try to change the plugs and wires again and get it to the dealer again.
Any suggestions? Anyone else have this problem?? Why does the car just shut down as soon as the light comes on?
Help me please!
JennyTib is offline   Reply With Quote
Old 09-07-2005, 05:48 PM   #2
BigTDawg
Send a message via AIM to BigTDawg
Re: 2000 Tiburon Check Engine light on again!!!!
Help me please!
i wouldnt replace the plugs and wires if its not gonna work either get it towed to the dealer or try takeing out the plugs and wires and putting them back on and then take it to the dealer
BigTDawg is offline   Reply With Quote
Old 09-07-2005, 06:30 PM   #3
Baail6220
What kind if plugs did you put in it? It most likely won't make a difference, just making sure you didn't put in bosch or some kind if crappy plug. (if you didn't know) Bosch plugs arent recommended for hyundais because they run at a high temp. NGK is the best plugs for them.
Baail6220 is offline   Reply With Quote
Old 09-07-2005, 07:39 PM   #4
nisco
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
thats alota swapping if the plugs and wires... something else must be wrong with the car...
check the:
battery
altenator
oil
etc etc
check the basics
try and bring it to a pep boys or an auto zone, and have the codes read... (what hyundai does) but since this is the 3rd time... something else is up...
almost that time
my sig made mommies cry, thats why i had to change it..
nisco is offline   Reply With Quote
Old 09-08-2005, 04:18 PM   #5
JennyTib
Re: Re: 2000 Tiburon Check Engine light on again!!!!
My husband changed the plugs & wires last night & the check engine light did go off. He talked to a mechanic that he knows and even showed him the old plugs & wires. The mechanic suggested that we buy a higher quality plug. (he says split fire) We've been getting the ngk that Hyundai recommends. He also suggested taking it to Hyundai and having the catalyitic converter checked out. (i think it's still under warranty)
What do you guys think?
& thanks for the replies so far!
Old 09-08-2005, 09:15 PM   #6
JennyTib
Re: Re: Re: 2000 Tiburon Check Engine light on again!!!!
update-----my husband drove it and after about 5 miles it died. We're thinking that it is the converter & it's going to the dealer in the morning.
I'd love to take it to have the codes read, but the nearest auto parts store is about 15 miles & the dealer is 40 miles! I live in the boonies, lol.
Old 09-09-2005, 03:09 AM   #7
Baail6220
Re: Re: Re: Re: 2000 Tiburon Check Engine light on again!!!!
[quote=JennyTib]update-----my husband drove it and after about 5 miles it died. We're thinking that it is the converter & it's going to the dealer in the morning.
I'd love to take it to have the codes read, but the nearest auto parts store is about 15 miles & the dealer is 40 miles! I live in the boonies, lol.[/QUOTE
Could you give us some more information so we can help? Like if it made any sounds while it died, what does it do when you try to start it? Any info would help. Also did you ever get your ignition coil replaced? I have a 2000 Tiburon and I had to get it replaced. There is a coil pack (also distributorless) in it, I would try to replace that if you didn't already. I don't know for sure, but I don't think a bad cat would make the engine die.
Old 09-09-2005, 08:43 AM   #8
JennyTib
Re: Re: Re: Re: Re: 2000 Tiburon Check Engine light on again!!!!
The rpms slow then dies, no noises really. Never had the coil checked. It is being checked out by the dealer today, I'll give you an update when I hear from them.
Old 09-09-2005, 08:46 AM   #9
JennyTib
Re: Re: Re: Re: Re: Re: 2000 Tiburon Check Engine light on again!!!!
ALSO--if you let the car cool down for about an hour it will start again.
Old 09-10-2005, 01:31 AM   #10
Baail6220
Re: Re: Re: Re: Re: Re: Re: 2000 Tiburon Check Engine light on again!!!!
So when the car dies, try to start it back up. There should be some kind of noise like a clicking (starter) or something. If you try to start it again does it crank or can you just hear the clicking?
Old 09-10-2005, 09:58 AM   #11
JennyTib
Re: Re: Re: Re: Re: Re: Re: Re: 2000 Tiburon Check Engine light on again!!!!
The dealer said the code was the crank shaft positioning sensor? Never heard of that one. He said he has changed a lot of them on tibs with as many miles as I've got. (108,000)
It's fixed but we're having the timing belt changed while it's already up there.
You guys ever heard of that code?
Old 09-10-2005, 11:57 AM   #12
BigTDawg
Re: Re: Re: Re: Re: Re: Re: Re: Re: 2000 Tiburon Check Engine light on again!!!!
why couldnt they figure that out the first time it was in there?
Old 09-10-2005, 12:57 PM   #13
nisco
Tib Guy
i knew it was something else...
bad crank shaft sensor...?
they said the crank shaft itself is fine tho?
and good move on the timing belt...
good luck with the car now
almost that time
Old 09-12-2005, 04:46 PM   #14
JennyTib
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 2000 Tiburon Check Engine light on again!!!!
I should have it back tomorrow. They replaced all of my belts while they had it. They said that this sensor was common to go out with the mileage I had. (108,000)
Old 09-12-2005, 11:02 PM   #15
nisco
Tib Guy
well i sure hope everything is worked out when you get it back
almost that time
