How to overcome understeer in an FWD
Any ideas?
As of now I've been swinging the back of the car around, but there must be a better way... |
Re: How to overcome understeer in an FWD
besides hand/e-brake, i know of none....
Thicker rear anti-roll bar, smaller front anti-roll bar. Increase tire presure in the back, and last but not least...drive better. That's all the advice I can give.
Well there is a driving technique called left foot braking. I think the idea is that you are turning, ok and now u have feet on both the brake and accelerator, so when you understeer you can press the brake a little and then start accelerating again. I dont remember how it goes but its something like that.
I want to be a sleeper. |
ways to create oversteer:
1. put shitty tires in the back of your car 2. weight loss in the rear of the car 3. put grippier tires in the front 4. put thick sway bars in the rear if all else fails, spray water on your rear tires! there you go... |
thanks, ya I know about left foot braking and it works, but course I'm going to need more practice
#7 | |
In Stereo where available
![]() Join Date: Mar 2003
Re: Re: How to overcome understeer in an FWD
Lift off of the gas, and you get a very shallow oversteer on most FF cars. If you have a stiff anti-roll bar on the rear, you can get more oversteer than you want (I can honestly say that I've gotten nastier oversteer out of my '82 Tercel then I've ever had to deal with in any of my rear engined cars!)
I also detailed an interesting techinique for using understeer to create oversteer in the thread in this forum about "snow drifting" but it's a pretty tricky technique to use on a dry surface.
![]() Support America's dependence on foreign oil - drive an SUV! "At Ford, job number one is quality. Job number two is making your car explode." - Norm McDonald. If you find my signature offensive - feel free to get a sense of humor. |
#8 | |
Supermodified
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2003
Also, try dialing a few degrees of toe-in into your rear suspension. It's a trick ACR Neon drivers use to great degree and really helps free up an FF chassis. Also, if you can, zero out any rear camber you might have.
After that, it's just like the others have said; left-foot braking, stiff rear sway bar, and a few more pounds of pressure in the rear tires. A friend and I did this list of setup stuff to a Geo Storm with great success. Really helped in autocross.
Proud Owner/Operator of Haven Raceway and Hobby! |
#9 | |
thanks for help guys, any other ideas?
#10 | |
For now, increase the rear tire pressure and see where you're at.
#11 | |
![]() Join Date: Feb 2003
snow is your friend...hahhahheheh
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines" --2OF9-- (DSM team specialist) ;D #808/1000 |
#12 | |
![]() Join Date: Jul 2002
All types of drifting tips - http://www.driftsession.com/drift_te...oeshifting.htm
Learn suspension in & out so you can get the proper set-up --- get a book called How to Make Your Car Handle Go to a closed course & practice - dont forget a shit load of tires. |
#13 | |
Actually, with FWD you'll find your tires wear very little at all (a bonus over FR) because you're not spinning them to break traction. However, if you do it alot, they'll wear irregularly.
#14 | |
pssst wanna know a little secret?
make ur rear suspension stiffer than your front and your car WILL oversteer. But becareful, you wont handle as well as having stiffer front. |
#15 | |
![]() Join Date: Oct 2003
lets see..
less toe in at the rear softer springs at the front, stiffer at the rear |
