Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-03-2004, 09:57 PM
balki14 balki14 is offline
Question Brake Control Plug
I have a new Dodge Ram 2500HD 4x4 with the Hemi. I have a Travel Trailer that I purchased a Prodigy Brake Controller with a plug in adapter designed for the 2004 Dodge Trucks.
The brake controller end plug is quite obvious, but I cannot find the plug under the dash to plug th eother end of the wiring harness into. Need some help here.
Old 07-05-2004, 02:31 PM
Dodgeintheblood Dodgeintheblood is offline
Re: Brake Control Plug
If your truck is wired for the brake controler it should be near / above the park brake pedal.. If not talk to your local Dodge dealer they should be able to tell you exactly where it is... Good Luck!
Old 07-05-2004, 07:48 PM
slantsixness's Avatar
slantsixness slantsixness is offline
If you can't find the plug, then your truck doesn't have the towing package and you need the other (pre-2004) kit.
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
