Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-27-2003, 06:23 PM
ripleys1 ripleys1 is offline
Question 94 Surpreme, 3.1 Idles fine, stalls on gas, advice pease?
We have a 1994 Cutlass Surpreme SL v6 3.1
It idles almost fine.
But as soon as we give it gas it stalls.
It will start again, but same think happens.
Already replaced the fuel filter.
Any ideas, please help.
Thanks
Old 10-28-2003, 10:33 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 94 Surpreme, 3.1 Idles fine, stalls on gas, advice pease?
Many things can cause a tip-in stall.
Does the SES light come on?
What could be going on is the possibility of low fuel pressure.
Do you have access to a fuel pressure gauge?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-28-2003, 10:48 AM
Fuel Pressure
Thanks for taking the time to write.
No accesss to a fuel pressure gauge, but
If you suggest a part to change, I will buy it and have it installed.
Car is now parked in driveway
Thanks
Old 10-29-2003, 07:19 AM
GMMerlin's Avatar
I know stuff
Re: Fuel Pressure
Thanks
I wouldn't recommend any parts until some diagnosis is done to determine what is at fault. Just throwing a part at your problem is a waste of money and time.
If you want to spend some cash, purchase or borrow a fuel pressure gauge that will screw on the shrader valve, a cheap multi meter and a test light.
With those 3 tools you can diagnos just about anything.
Low fuel pressure can cause the engine to stall because there isn't enough pressure to support any engine load above idle.
A TPS can cause a stall if it goes open or shows a false reading while pressing down on the gas pedal.
Numerous other sensors or wiring problems could cause you problem.
GM WCT
PM Me for details
Old 10-29-2003, 10:08 AM
Thank you
Thanks for writing.
I was hoping it was a very comman problem.
But, I will take your advice.
Pep Boys siad $70 and they will put it on the machine.
Thank again.
Joe
Old 11-25-2003, 05:06 PM
shekky shekky is offline
Banned
Send a message via MSN to shekky
i had the same problem with a 3.1. the map sensor was loose. i reconnected it and everything was fine.
99 Caravan Sport Rough Idle and Stalling blase Caravan | Voyager 8 10-10-2010 07:48 PM
95 tsi really low idle and stalls.. Please help please Brenthb25 Eclipse Problem Diagnosis 3 07-20-2010 10:41 PM
