Go Back   Automotive Forums .com Car Chat > Dodge > General Discussion
Old 11-03-2003, 04:27 PM   #1
89 Turbo1
Angry Turbo trouble
Hi. I just bought an 89 Daytona turbo CS. It runs and idles very nicely though. When I floor it the turbo makes a big wooshing noise when under boost. Is this normal? The car drives fine under part throttle conditions, but under full load it makes a lot of noise but doesn't accelerate quickly at all. I am new to turbo’s so I don’t know want the problem is. Thanks
89 Turbo1 is offline   Reply With Quote
Old 11-03-2003, 10:16 PM   #2
theslicksteve
Send a message via Yahoo to theslicksteve
Re: Turbo trouble
[quote=89 Turbo1]Hi. I just bought an 89 Daytona turbo CS. It runs and idles very nicely though. When I floor it the turbo makes a big wooshing noise when under boost. Is this normal? The car drives fine under part throttle conditions, but under full load it makes a lot of noise but doesn't accelerate quickly at all. I am new to turbo’s so I don’t know want the problem is. Thanks[/QU
i would check your turbo pressure hose. on 2.2 or 2.5 sohc it is going from turbo to the throttle body. check both ends of hose and also check relief (blowoff) valve hose. it tees off of turbo press hose and is about 3/4 inch in diam. if any clamps are loose it will leak and make a loud whoosh sound. i have a 89 acclaim turbo it happend on.
theslicksteve is offline   Reply With Quote
88 thunderbird turbo trouble codes tomjanovich Thunderbird 0 03-30-2005 06:11 PM
turbo trouble tfoti Eclipse Problem Diagnosis 7 11-10-2004 08:13 PM
Turbo trouble jpdmcm Passat 2 08-31-2004 06:11 PM
87 shadow es turbo trouble niz General Discussion 4 11-03-2003 10:33 PM
HELP!!! d16z6 turbo trouble delslowsi '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 08-26-2003 01:14 AM
