Old 10-25-2003, 10:00 PM
JScot JScot is offline
Unhappy 88 Won't Start
My 88 4.0 automatic with Renix Multi point Injection won't start. I was having idling problems and cleaned the Idle Air Control valve. I drove it once and it seemed to work fine. Then I changed the plugs ... should have left well enough alone. Since changing the plugs I get no current to the coil, no spark, no nuthin'. I've read here that the fix is usually to replace the Crankshft Position Sensor. I checked the CKP with an ohm meter and get the same reading as with a new CKP. Do I still need to replace the old one? Is there something else I'm missing? Any help will be appreciated. I want my jeep back.
10/26 I replaced the CKP/CPS. It turns over as before but still has no current to the Coil and I don't think I have fuel either. Can someone tell me how I can check to see if the ignition Control Module is receiving current? The only thing I notice is one of the 4 relays clacks more than once when I turn on the ignition This is getting really frustrating.
10/28 Tried a used ignition control module from Jeep dealer (he said it was off an old Renault). This did not solve anything.
10/29 Still can't determine why no fuel or spark. When I turn on the ignition the 2nd relay just keeps clacking away. I've switched relays and whatever I put in the 2nd position just clacks. Power is going to the starter but not to the coil. I've replaced the secondary +batery cable as it was pretty well shot but still nothing good happens. Sure could use some help.
Old 11-20-2003, 09:47 PM
uuncle uuncle is offline
I had a 1991 .same thing no spark. i was testing with a test light. the wires going ...to distributer and i heard a buzzing noise ...tried to start it and it fired right up runs strong now .talked to dealer they said stuck relay . got unstuck!! sounds good to me !!!! good luck
Old 11-21-2003, 07:38 AM
Thanks uuncle. After much frustration, I took it to a mechanic. Apparently when I was changing the plugs I knocked off one of the wires that are attached to the primary engine ground below #6. There were supposed to be 4 wires coming off that ground and I guess I figured 3 was plenty.
1996 Jeep Cherokee Won't Start mocojpo2003 Cherokee 16 09-14-2011 04:39 PM
92 Lumina Won't Start ICM Voltage Brndo Lumina 9 05-03-2010 12:37 AM
99 Regal LS stalled now won't start mfraumeni Regal 7 04-05-2010 01:38 PM
99 Saturn SL Won't Start! turtleisland SC/SL/SW 5 08-13-2009 10:52 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 04:20 PM
