Old 09-24-2003, 06:47 PM   #1
T-Mo
T-Mo's Avatar
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Crank Pulley Problems
I finally finished putting the head on my civic, now we are trying to put the timing belt on and this crank pulley bolt is hard to get off. Any ideas on what I should do??
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
T-Mo is offline   Reply With Quote
Old 09-24-2003, 07:19 PM   #2
dirty91crx
dirty91crx's Avatar
Send a message via AIM to dirty91crx
impact gun.....the only way i do it!
so whats wrong with a d15b2 again?
dirty91crx is offline   Reply With Quote
Old 09-24-2003, 11:37 PM   #3
plkelley
plkelley's Avatar
Send a message via AIM to plkelley
I cant remember who gave me this tip but it works...
Put #1 piston at bottom dead center..make sure valves are closed..fill cylinder with nylon rope then get a real big bar...did mine this weekend..worked great
Honda...An Army Of One
plkelley is offline   Reply With Quote
Old 09-25-2003, 06:34 PM   #4
civickiller
Send a message via AIM to civickiller
i just used an impact but i had to turn the air pressure up from stock 90 to 120
Team Lonely Drivers
civickiller is offline   Reply With Quote
Old 09-25-2003, 06:40 PM   #5
gunnmen01
gunnmen01's Avatar
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Never heard of the rope in the cylinder, but i suppose it would work...we have a special tool at the dealership that locks into the crank pulley so it wont turn... but usually an impact with about 600 ft lbs of torque will loosen em right up...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
gunnmen01 is offline   Reply With Quote
Old 09-25-2003, 07:06 PM   #6
T-Mo
T-Mo's Avatar
Re: Crank Pulley Problems
thanks folks, I had to go to my old house and get our compressor. The impact gun took it right off. Everythings in tact now. It is now ready to be put on the road. I will have some update pics up soon.
'93 Honda Civic EJ2
Old 09-26-2003, 12:03 AM   #7
amy@af
Traffic Directing Admin
amy@af's Avatar
Send a message via Skype™ to amy@af
if you don't have an impact there are 2 other methods. if the engine is still in the car then have someone step on the break. if it is out of the car then use a screwdriver (or whatever) and stick it through the holes of the crank pulley to chalk it in place.
of course an impact works the best
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
amy@af is offline   Reply With Quote
Old 09-26-2003, 01:55 PM   #8
4-Door Flunky
AF Premium User
I tried the 'In gear, foot on brake' method, with no luck.
Finally got my neighbor to bring his compressor and impact gun. Still now luck. He finally dragged over his 150 PSI compressor, and whoood'n! Off it came!
Flunky
4-Door Flunky is offline   Reply With Quote
