cv joint help?
hey i was wondering if anyone has done a faq about cv joints, i haven't done it before and i can't afford to do it at a shop so please help i need to get it done in one day because i only get one day off from work a week.
I'm no street racer nor do want to be, my goal is a fun car... that leaves SUVs in the dust. current car: red 90-civic-STD-hb with dx trannie, ecu, shift knob, & rear seats. i hate my vynil seats. p.s. i am once again with computer, please forgive the one year leave of absence. |
Just replace the axle with a reman. piece. Should only take about 1hr to replace - faster if you have done it before.
dont be scared to do stuff yourself cuz if you dont try you'll never learn, its not that hard, get a book and take your time, and the next time it will be so easy
2002 Acura TL Type S 1991 Honda Crx Si |
chocolate
thanx, for the boost guys i'll post my results morrow.
man when i changed my cv boot, it took me like 3 hours cause first i changed the outer ones, then i realized u change the inner ones when u change the outer ones because they come off the outer side. so i had to take off the boot again and pull hte innner ones out and change them and put hte outer ones back on. i used like so much of those clips that day. like he said, do it yourself or youll never learn, i found it by doing it
http://www.fourthgenhatch.com FOR SALE: Get this stuff out of my house! -Stock hood (red) $30 -Stock Rear Spoiler (red) $30 -Stock mirrors $30/both -Stock side front and rear side glass $30/piece |
ok to anyone who's still online i can't get my new axel into the trannie, any ideas?
There are 2 kinds of axles for 4th gen civics, some have 23 splines, some have 26. Don't quote me on this, but I think the civics with the 4 spd manual trans had the 23 spline ones. But you need to mark one on the old axle (as a starting point), and count how many are there, and you need to count how many are there are the new axle.
If they are the same, and you are just having trouble getting it to snap in, start the one end in the trans, and the other end in the wheel assembly, and use the wheel part like a slidehammer to pop it in place. MAKE SURE you have the splines all lined up before you do this! If everything is lined up, doing that doesn't hurt anything, and could save you alot of effort. Hope something there helped. |
well thanx for the tip but i changed my trannie myself so i know i have the right spindle # and even double checked before i came back. i do appretiate the help though but now i have a new problem i can't get it into the hub or wheel assembly i think they would be the same thing. it's really pissing me off any ideas.
The transmission side (inner splines) of all the axles were the same. However the hub side (outer splines) of the HF and STD was 23, while all others were 26.
To get the axle into the tranny you have to get it past the snap ring. To do this all you need is one strong blow to the axle. What I did is make sure the axle is as straight as it can be, than with a the top of a rubber mallet in the palm of my hand just punch the back of the axle and the force is enough to seat the axle in. Than for the hub side just pull on what you have to to get the clearance and than maybe turn the hub by the wheel stud to line up the splines.
thanx for the advice i read your 'how to' to get it into my trannie but i just found out that the people i had put in my dx trannie gave me a half 26 spindle half 23 spindle axel instead of changing my hub. that really pisses me off but they did tell me they didn't change the hub and i did ask them to do it in the cheepest way possible, now. is it possible to get a 23-26 spindle axel or do i just have to change my hub tomorrow morning b4 work. they found someone to cover for me from another store but i want to get in there as soon as possible... any advice?
hey could i also get a 2g integra hub just wondering so i have more options to look for at the junkyard tomorrow.
zipidy doo i can see swirls or color and everything i look at is swerling
, damn it's fun halucinating when you crave nicoteen. i prolly can't spell either but i am just being silly....... ow, my head hurts
How can you have a half 23 and half 26 spine axle? The Inner splines are all the same for all the Honda axles. The outsides were either 23 for the HF or STD or 26 for the rest of them. Count the number of splines your hub has. Use axles with that number of outer splines.
Re: cv joint help?
Keep it real, and share the knowledge..... Say NO to Primer!!
