Go Back   Automotive Forums .com Car Chat > Toyota > Previa
Old 02-10-2010, 05:26 PM   #1
vet_stingray
how do i tell if my 92 has abs or not?
Sorry I'm usually pretty good with engines but everything else on a car is over my head. I need to order a new bracket for my brakes but don't no how to tell if my van has abs or not?
vet_stingray is offline   Reply With Quote
Old 02-10-2010, 06:15 PM   #2
danielsatur
Re: how do i tell if my 92 has abs or not?
1) Go 30mph, and hit the brakes!
2) Look for ABS module under the hood.
3) There should be a fuse for the ABS module.
4) During the self test prior to start, there should be an ABS light indicator.
Caution - Make sure, that nobody is behind you.
danielsatur is offline   Reply With Quote
Old 02-12-2010, 12:11 PM   #3
jdmccright
The RustBuster
jdmccright's Avatar
You can call or go to any Toyota dealer and give them your VIN. They can tell you if ABS was installed as a factory option and can print out all the options your van came with from the factory.
Another way, though dirtier, is to turn the front wheels all the way to one side and peer behind them to look for a small wire going from the brake rotor backing plate, up the strut, and into the engine compartment. This is likely the ABS signal wire from the sensor to the controller.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
jdmccright is offline   Reply With Quote
Old 04-24-2011, 11:05 PM   #4
bluefever
simplest way is to pop the hood and look on the passenger side and see if there's a big pump with lines coming out of it,if it has abs it won't be hard to notice,if u don't have it the space will look pretty empty
2013 Ford C-Max Energi, 2005 Ford Five Hundred Limited AWD, 1991 Dodge Monaco LE
bluefever is offline   Reply With Quote
Tags
1992 , abd , brakes , previa , van
