hello i got the swap done in my 95 4dr civic; and i am having trouble with my shiftlinkage (i'm hoping)...it's not allowing me to downshift into 2nd and sometimes when i do the 1st to 2nd shift it grinds and sometimes it doesnt i'm hoping its not the syncros. i used an 91 accord shiftlinkage and i ran it under the steering rack its kind of tight; there isnt alot of play in the linkage. just want to know your thoughts or if you have heard anything about this?
HCP said to double clutch when down shifting, but there has to be a better way to fix the problem. Also heard something about possibly needing a short shifter to shift properly can any one back this up (and if so what short shifter will work)? Any help is GREATLY appreciated. |
if you have to double clutch, then its probably a syncro. unless the shift linkage is touching something
Thank you for your answer, I'll check it out and see if it's hitting anything; as soon as my friend gets it back from being painted. Thanks Again.
AM HAVING THE SAME PROBLEM.BUT I USED THE ACCORD TRANNY AT FIRST FOR THE LONG GEAR RATIO AND IT WAS VERY HARD TO GO INTO GEAR.THEN THE TRANNY WENT UP ALL TOGETHER.THEN I WENT TO THE H23 TRANNY SAME THING!.NOW AM WITH THE H22 TRANNY AND IT STILL DOING THE SAME THING THE SHIFT LINKAGE IS NOT BINDING UP.SO WE STILL WORKING ON THAT BUT IT ONLY DOES IT WHEN EVER I TAKE THE RPM TOO 8K I ALWAYS HAVE TO LET THE RPM DROP TO AROUND 5K TAP THE GAS THEN SHIFT.
01" ACCORD PERFORMANCE MODS: JDM H22A MOTOR SWAP EIBACH PROLINE SPRINGS DC SPORT SHORT THROW SHIFTER GReddy EVO CATBACK EXHAUST O15 18"WHEELS NITTO 450 REV HARD T3/T4 TURBO WITH .54 TRIM PWR 31X11X3 INTERCOOLER ADJUSTABLE FMU 12:1-14:1 RATIO 550cc INJECTORS VAFC MANUAL BOOST CONTROLLER GReddy TURBO TIMMER AEM CAM GEARS AEM UNDERDRIVE PULLYES ACT EXTREAM CLUTCH/PRESSURE PLATE ADDED 1 EXTRA FUEL PUMP(INLINE) BOOST GAUGE EGT GAUGE AIR/FUEL RATIO GAUGE TURBO-XS RFL BLOW OFF VALVE BFG DRAG RADIALS 225/50/15(2) FUTURE PLANS: FULL BOTTOM/TOP END BUILD UP AM 8PSI NOW. |
