Go Back   Automotive Forums .com Car Chat > Ford > Taurus | Taurus Wagon
Old 01-24-2020, 04:22 PM   #1
Allegretto
Allegretto's Avatar
Send a message via Yahoo to Allegretto
2007 Taurus transmission bad maybe?
I went to leave for work, as we do, and i put my car in reverse. It moved a couple of inches and then just stopped. Now no matter what gear i put it in it acts like its in neutral. Had somebody look at it, he said get a new transmission. Id rather make sure before i spend that kinda money. Any and all info greatly appreciated as always.
Allegretto is offline   Reply With Quote
Old 01-26-2020, 09:47 AM   #2
shorod
SHO No Mo
shorod's Avatar
Re: 2007 Taurus transmission bad maybe?
For starters, check the transmission fluid level and if it's low, fill it to the proper level. Also, there should be a cable linkage between the gear selector and the transmission housing. Make sure the cable linkage is connected and functioning properly. This might require two people, one in the car holding the brake and shifting the transmission and one under the hood watching for proper movement of the cable and linkage.
You say it acts like it's in neutral. So if you don't set the parking brake and/or chock a wheel the car will roll freely, or is it more like it's stuck in park?
-Rod
