2009 Malibu electrical problem, gauges and dash lights
I have an electrical issue I could use some suggestions where to look for my problem. I bought this car 6 months ago, 130K miles, about a month ago I started seeing an occasional warning message on the dash while driving, but would quickly clear itself. Power Steering and Service ESC were most common. Then I started seeing all of my gauges drop out while driving, along with error messages mentioned, low fuel, and the security light would be on.
The problem has started showing up frequently now, a couple times for extended periods of time and I have got stuck where the transmission won't shift until I stop and restart the car. I have checked battery connections, power cable to fuse block, ground wires in engine compartment (found 3 different ones). Haven't checked starter cables but might look at those next. Today I got a bunch of diagnostic codes to register when this happened, along with a check engine light of course. Does this list of codes that registered point someone to an area I can focus my investigation? I'm still focused on wiring problem, bad ground, corrosion, or possibly bad BCM/PCM/ECM (not sure what modules this car has that could be affected), am I on the right track? Codes look like the CANBUS communication is effected as several different modules lost communication. U0100 - Lost comm with ECM/PCM "A" U0073 - Control module communication bus off P0700 - Transmission control system (MIL Request) P0575 - Cruise control input circuit P0150C - ? U0101 - Lost comm with TCM U0121 - Lost comm with anti-lock brake system (ABS) control module U0140 - Lost comm with body control module U2105 - ? C0561 - ? Thanks for the help! |
Re: 2009 Malibu electrical problem, gauges and dash lights
Has anyone had an issue like this before? I'm still trying to figure this one out. It might run for a week without a problem, then really act up for a couple days. I have tried to clean grounds, clean power connections under the dash where the main power comes through the firewall, seems like it helps but then problem comes back randomly.
Anyone have a battery going bad that would cause something like this? This battery holds a good charge, 12.6v with the car off, but I've heard of strange electrical issues going away after changing battery before. Thanks |
Your worst nightmare
![]() Join Date: Oct 2004
I would have a look at the fuse box itself. I just watched a video on youtube about a Malibu with random no start issues that ended up being caused by bad pins on the fuse box where the relay plugged into. GM wasn't making the greatest cars at that time (they still don't) and it shows in the build quality.
I have continued to troubleshoot, taking the engine compartment fuse box apart and cleaning connections, cleaning connections and ground wires at the BCM mounted on the right side of the center console. No luck yet, still having problems.
Does anyone have a diagram showing control module locations, and ground wire locations for this car? If so that would be extremely helpful! Thanks |
A990 racer
![]() Join Date: Mar 2002
To properly check the battery , you need to do a load test.
Battery was load tested and tested good. I had an alternator go bad and replaced the alternator, along with the main wire going from alternator to starter, as it was rubbed part way through on a bracket it was tied to. Hoping this would resolve my problems, but didn't change anything.
Everything I read about this type of problem on other websites people make multiple trips to the dealer, they do random things like replace cables, battery, throttle body, pedal sensor, etc, and the problem always comes back until the owner gets mad and trades off the car. I can't find anyone who has resolved this kind of problem. I'm leaning towards it being a problem in one of the modules. Does anyone know what modules I can replace without having a dealer program them? And which ones would I need a dealer to program after I replace? What if I get a set of modules from a junk yard and put them all in as a set, does that work? |
#7 | |
This generation of Malibu ('08-'12) is closely connected to the prior one ('04-'07), the latter of which I am VERY familiar with. This issue cropped up fairly frequently with that gen and it was most always a BCM going bad. Sorry to say, the solution was usually to dump the car. Avoid the newer generation '13s (first year) because they also have a slew of (different) problems.
#8 | |
Some of my research pointed to the BCM being a common failure that would cause this kind of behavior, so today I picked one up at the salvage yard for $50. I stopped by the GM dealer and installed it in the parking lot, then had the dealer program it. They tried, but their tools would not let it be reprogrammed. They printed out a paper that showed that once a VIN or odometer reading was programmed into the BCM it cannot be changed. So used BCM is useless for this car.
Even so, I could run the car with the used BCM, it just activated the theft lock so my radio didn't work, it showed "locked" on the display. I didn't notice anything else that didn't work. While running the used BCM I experienced the same problem, so I think it is safe to say the BCM wasn't the problem. I don't think this is the cause of my problem, but the negative battery terminal doesn't tighten down as tight as I would like to see, I might swap a battery from another vehicle and replace the negative cable just to completely rule it out. Next steps might be tracing more wiring harnesses to see if I can find any damage or corrosion on pins, but I've covered this pretty well already and haven't found anything. Other ideas welcome, thanks! |
| Tags |
| communication , dash , electrical , gauges |
