Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 11-05-2006, 09:38 PM
RVTRichard RVTRichard is offline
Rear Hatch Lock
It seems that the failure of the Rear Hatch Locks on the Lumina Vans is common. Does anyone know why?
Thanks
Old 11-06-2006, 06:21 AM
knuckle ears knuckle ears is offline
Re: Rear Hatch Lock
The handle where the key goes in does fail and break off often. The handle seems to be the only place to pull the gate open. Once you replace the handle you realize their is another place down by the license plate to pull on. The lock handle lasts a lot longer then.
Old 11-06-2006, 08:29 AM
Re: Rear Hatch Lock
I'm sure that the lock handle is also a problem but I'm refering to tha actual lock. The lock itself seems to fail on a lot of these vans. You hit the power lock button and eveything locks except for the rear hatch. I've talked to countless owners who have experianced this but could never find out why this is happening.
Thanks
Old 11-06-2006, 10:12 AM
Re: Rear Hatch Lock
Three things can go wrong.
The pin in the solinoid part of the lock mechanism is missing or the mechanism has slipped away from the key cylinder hole. The pin keeps the lock cylinder from moving as you turn the handle.
The solenoid is defective or the wire has come off. You should be able to hear it as you lock the van.
The arms that connect to the solenoid and then to the side latches are not attached anymore.
You would have to take the inside panel off the gate to see. Not too hard to do and you will be able to determine what is wrong.
The Following User Says Thank You to knuckle ears For This Useful Post:
tinkering (05-18-2023)
Old 05-18-2023, 12:57 PM
tinkering's Avatar
tinkering tinkering is offline
In the 200 Club
Re: Rear Hatch Lock
I am starting a new thread on the mechanical failure of these rear locks/handles.
1923 Model T 'Stake' Truck, see in Legends of the Fall
1949 Chevy 3/4 Ton, had 214 ci now 235ci
1959 Dodge Mayfair
1986 Ford Ranger 4 cyl
1993 Pontiac TransSport 3.8
1996 Chevy 3/4 Ton 4x4
1999 Oldsmobile Alero
2004 BMW 330i
