Go Back   Automotive Forums .com Car Chat > Toyota > RX300/RX330/Harrier
Old 06-02-2018, 03:35 PM   #1
kennethb80
Exclamation Oil Leak from Crankshaft
Good afternoon all,
I have a 2000 Rx300 and it currently has developed an oil leak from what I can tell is the crankshaft seal. I am wondering if anyone has already replaced this seal and how much of a pain it will be to replace?
I have already done both oil pans so I know that is not leaking, I was able to clean around the upper pan and lower motor to try and see where the leak was coming from so that is why i know that it is leaking around the crankshaft area. I could see a stream form from behind the crankshaft pulley and run down the back of the engine.
I know the part is like $5 and I am guessing that I will have to pull the timing belt to get to this leak, if anyone has done this before and has pictures or a helpful walk-through that would be great.
kennethb80 is offline   Reply With Quote
Old 03-23-2020, 06:32 PM   #2
gewone
gewone's Avatar
Did you manage to get this fixed?
gewone is offline   Reply With Quote
Tags
crankshaft , leak , oil
