Go Back   Automotive Forums .com Car Chat > Jeep > Liberty
Old 06-01-2018, 07:41 PM   #1
joeyd50
A/c ????
2002 Liberty 3.7 ac kept going off and on blew out the clutch with compressor and lots of rusty dust came out. ac worked a little better but would still on occasion go off an on so I pulled the clutch and sanded all the rust off and now I have no ac. Any help please.
Thanks
Joe
joeyd50 is offline   Reply With Quote
Old 06-02-2018, 08:23 AM   #2
brcidd
brcidd's Avatar
Re: A/c ????
Clutch rust has nothing to do with performance of the clutch....it is quite normal. Did you notice how many shims came out from behind the clutch? and put them all back to achieve proper air gap? to try to maintain .020" or so of air gap?
First thing to check is refrigerant level when there is an a/c inop or inadequate complaint. my data show 65% of a/c issues are low charge due to a leak somewhere. Recharging will usually make it work for awhile, The only way to know if you are low on refrigerant, is to remove it and weigh it. pressures alone will not tell you. Heck, last car I looked at was double charged because owner had been adding refrigerant....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 06-02-2018, 05:19 PM   #3
joeyd50
Re: A/c ????
I actually didn't pull the clutch just cover with the one nut in the center, thats where all the rust was. I think thats the magnet.
Thanks
Joe
Old 06-02-2018, 09:17 PM   #4
brcidd
brcidd's Avatar
Re: A/c ????
If what you did was unscrew a bolt (or nut) and gently wiggle out an armature plate (you may be calling this a cover?). and the base was splined to slip onto the compressor shaft- then you did pull of the clutch driver....
'99 GMC Yukon
Old 06-11-2018, 11:04 AM   #5
joeyd50
Re: A/c ????
brcidd, I really appreciate you trying to help me, I went ahead and replaced the A/C clutch, the armature plate, pulley and the magnet, the new clutch came with 3 shims, I replaced the armature plate with the original shim, then 2, then 3, then all 4 , but the A/C won't shut off the clutch is always engaged.
Thanks
Joe
Old 06-15-2018, 01:19 PM   #6
rhandwor
Re: A/c ????
Thanks
Joe
I think you added to many shims. You need about .0035 inches Gap when the clutch is off. I use a 35 thousand feeler gauge. It has a bearing for when the ac is off.
rhandwor is offline   Reply With Quote
