Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 04-09-2010, 02:43 PM   #1
spugeddy
suspension making noise after strut replacement
Well it was making noise before the strut replacement, but I bought two new Monroe front struts, and had them put on, but I didn't replace the mounting hardware at the top of the tower. Sorry can't remember the name of it.
Still when I go over bumps or railroad tracks, it is the same "broken shock" sounding clank (metal on metal).
Any thoughts
spugeddy is offline   Reply With Quote
Old 04-09-2010, 02:56 PM   #2
Airjer_
Airjer_'s Avatar
Re: suspension making noise after strut replacement
Stabilizer bar links or bushings.
Airjer_ is offline   Reply With Quote
Old 04-09-2010, 03:04 PM   #3
spugeddy
I've done the P171.... repair, and brakes, shocks, etc on other cars..
Is this repair hard. And do you have to get an alignment afterwards?
Sorry for the newbie questions.
Old 04-09-2010, 06:37 PM   #4
northern piper
northern piper's Avatar
if you aren't doing any tie rods than the alignment isn't necessary really. If you're doing the sway bar bushings and end links, the next thing is your lower control arms and tie rods. You may be looking at doing the whole thing. That's what I did last year and then got the alignment done. I was of the impression that within 6 months I'd be likely doing the rest anyway so while I had things apart..
Bottom line, I'd be your clunk is sway bar bushings.
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
northern piper is offline   Reply With Quote
Old 04-10-2010, 01:10 AM   #5
old89lsc
I replaced my struts with Monroe quick struts last fall. Boy did those things squeak like crazy when they were new. They squeaked over bumps and they squeaked when turning the steering wheel. They definitely sounded more like old shocks than my old shocks did. After use, they did quiet down. Overall, though, I am not impressed.
2008 Chevy Uplander
2001 Ford Windstar
1992 Chevy Corsica
1989 Lincoln Mark VII LSC
old89lsc is offline   Reply With Quote
Old 04-10-2010, 11:39 AM   #6
wiswind
In my case, the monroe quick struts were fine......but the stablilizer links were not.
Mine squeaked......clunked, etc after about 1 year........they were the nylon type....installed at the same time as the struts.
After a number of years, it is pretty hard to remove the stablilizer links without damaging them.
I would recommend that one use Moog brand for replacement links.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
wiswind is offline   Reply With Quote
Old 04-12-2010, 10:10 AM   #7
spugeddy
I was under the van this weekend and grabbed hold of the stabilizer links (verticle bars attached to the shock?) and they are definatley making noise. The bushings (further back, to the rear) didn't appear to have any warping, or "air" between them and the metal, and the noise was coming from the verticle sway bar link....
SHould I pay someone to change both these areas.
I have the jacks, and jack stands, but don't want to get over my head if it is too much work.
Old 04-12-2010, 08:21 PM   #8
old89lsc
I don't know how hard it is, but if it turns out not too bad of a job in the driveway, please post it. Sooner or later I will have to replace mine and I would rather not pay for a job that isn't all that bad.
When I went to replace the struts my Haynes said that the steering knuckle would have to be removed. Well, I didn't really see going after that myself. I got a local Meineke to install the parts that I bought, saving me some money. I watched them do the job. It was easy; they put it on the lift, took off the wheels, and used an impact wrench to take off the bolts connected to the strut. The steering knuckles were left attached. I think that the whole thing was done in an hour by the two guys working on it. I felt like an idiot.
Whatever you decide, good luck.
2008 Chevy Uplander
2001 Ford Windstar
1992 Chevy Corsica
Old 04-12-2010, 09:03 PM   #9
northern piper
the end links are easy. the hardest part is detaching the nuts that hold onto the strut and the sway bar. They're usually corroded and need some coaxing. Use lots of pb blaster. Once they're off, the new ones get put in. Pretty simple job.
2000 windstar 3.8
Muskoka Canada
Old 04-13-2010, 07:27 PM   #10
wiswind
I was lucky with my '96 windstar........needed new sway bar links.....but the sway bar bushings are still original and in good shape after over 220K miles.
1996 3.8L Windstar
Old 04-14-2010, 09:44 AM   #11
spugeddy
I think I am going to try to links, and see it that solves it.
I'll post pics, or DIY of it if I am successfull.
Old 04-14-2010, 04:01 PM   #12
northern piper
wow those are some bombproof sway bar bushings! I average about 25k on the ones I have! We must have even lousier roads than I thought!
2000 windstar 3.8
Muskoka Canada
Old 04-14-2010, 08:57 PM   #13
wiswind
I think it also depends on the replacement bushing that you get.
My '96 could have 1 of 2 different diameter sway bars.......VERY close in size.....so if you get the wrong size......they won't last.
Also.....it depends on the material used to manufacture the bushing.......some are better than others.
The other thing that I read.
You do NOT want to use oil or oil based grease on the bushings, as that will soften (break down) the bushing material.
You use a silicone based lubricant.......I was given Motorcraft "Mini-Vent Window Lube" when I gave them the Ford Specification number that I got from the alldata manual instructions for the sway bar link bushing replacement.
That stuff is SUPER slippery.
Those 3 reasons are enough to make me leave good OEM bushings alone......my luck....I would spoil a good thing.
1996 3.8L Windstar
Old 04-18-2010, 07:58 AM   #14
spugeddy
I bought the Moogs and am going to put them on today. I'll post later.
One link had the grease fitting lubed, but the other side looked dry.
Should I try to top it off with the silicone?
Old 03-05-2011, 07:45 PM   #15
spugeddy
I attached a grease fitting to the sway bar links and added some grease.
The clunking I was getting from these new links has gone away.
