Go Back   Automotive Forums .com Car Chat > Ford > Crown Victoria
Old 04-18-2017, 08:18 PM   #1
Kevmilli
Fuel relay Mini fuse (shortage)
2005 Ford Crown Victoria Fuel relay mini fuse 20A keeps blowing out changed to a 30A same problem (Help)
Kevmilli is offline   Reply With Quote
Old 04-21-2017, 12:47 PM   #2
65comet
65comet's Avatar
Re: Fuel relay Mini fuse (shortage)
Almost everyone that works on a car will groan when they encounter this type of situation. There is a short somewhere that can be anywhere along almost the length of the car. Water may have leaked into the back of the fuse box and be causing a short there. The wire that travels back to the fuel pump might have rubbed off its insulation anywhere along its length and is shorting against some metal. The wire connector to the fuel pump could be bad. The fuel pump itself could be bad. It comes down to getting a good voltmeter and traveling along that length eliminating what is good till you find what is bad.
65comet is offline   Reply With Quote
Old 04-21-2017, 03:12 PM   #3
silicon212
Confoundingly Lucid
silicon212's Avatar
Send a message via ICQ to silicon212
Don't ever substitute a larger fuse for what came in there - there are reasons why fuses of a certain size are selected.
Check the wiring to the fuel pump and to the fuel pump driver module for shorts.
Positive power is always present at the fuel pump whenever the key is in the ON or START position - the 'ground' of the fuel pump is run through the fuel pump driver module to ground.
The fuel pump driver module is located in the trunk area, on the rear seat bulkhead behind the spare tire.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
silicon212 is offline   Reply With Quote
