Old 10-11-2016, 01:55 PM   #1
MatthiasRMS
How to record steering wheel angle while driving ?
Hi!
I was wondering, how can I continuously record the angle of the steering wheel while driving, and save this data.
I'd need to be able to start and stop the recording, and then save it.
Any idea, even if it's not an out of the box solution, will be much appreciated !!
Matthias
MatthiasRMS is offline   Reply With Quote
Old 10-11-2016, 05:09 PM   #2
shorod
SHO No Mo
shorod's Avatar
Re: How to record steering wheel angle while driving ?
The easiest way to do this would be with a scan tool or computer software that can access the stability control system of the vehicle and then datalog the steering wheel angle.
You might also be able to use some sort of logic analyzer to analyze the bit stream, but finding the protocol and bus detail for the specific vehicle you're working with could be tricky.
Another option would be to tap in to the sensor wiring with a buffered datalogger and pull off the information you are looking for. The sensor is likely either a hall effect sensor or optical rotary encoder and it would be relatively easy to calculate by monitoring the bit stream while turning the steering wheel from lock to lock slowly.
-Rod
Old 10-12-2016, 08:22 AM   #3
maxwedge
A990 racer
Thumbs up Re: How to record steering wheel angle while driving ?
-Rod
Nicely done!
Old 04-14-2017, 04:21 AM   #4
Arrius
Best way to do this is to use a telematics device on your vehicle and vehicle tracking software.
Last edited by shorod; 04-14-2017 at 07:48 AM. Reason: Removed possible in-line spam link.
Arrius is offline   Reply With Quote
