Go Back   Automotive Forums Car Chat > Dodge > Caravan | Voyager
Old 10-10-2016, 11:33 PM
MicSkip MicSkip is offline
Continuos Stalling
I have a 2014 Town and Country and I was wondering if any one has had any issues with the vehicle stalling at slow speed and while idling. This is becoming a recurring problem with my van and searching the internet has only giving me many broad answers nothing conclusive. The vehicle is a 3.6L FFV with 44,000 miles. Thank you for the help.
Old 10-11-2016, 06:08 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Continuos Stalling
Broad answers because there are so many things that can cause it. I take it your warranty is done. Have you read about the TIPM problems?
If this was a 4th generation van (01-07) I would jump on here and say it's related to the Idle Air Control (IAC) valve that allows air to bypass the closed throttle plate at idle. As I understand it there is no such animal on your 5th gen van because it has an electronic throttle system. Idle RPM is now controlled by your pedal, the PCM and a motor on the throttle body. The little I know is there's a transducer on your throttle pedal that sends electrical signals (no more steel cable) to the PCM. The PCM commands the motor on the throttle body to move the throttle plate which regulates your engine RPM at idle or at speed. Something may be amiss in that chain. Logic is telling there may be a sensor effecting your idle or there may be a calibration or reprogramming procedure to correct it. That is pure speculation. Enough of that. Hopefully, someone can help you further.
By any chance have you seen the ETC light come on? That tells you the electronic throttle control has a problem and a code is stored. Looks something like this minus the white border: http://repairpal.com/images/managed/...ntrol_Bolt.jpg
Continuous stalling? That does not mean it starts and immediately stalls correct? That would put the anti-theft system at the top of the list.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 12-20-2016, 12:41 PM
EA6BMECH's Avatar
EA6BMECH EA6BMECH is offline
I know this sounds funny, but is the gas cap on good?? We had an older one and dad figured out that mom never tightened up the gas cap good enough. Would cause the car to stall. Then it would start up and go again for a while.
