Go Back   Automotive Forums .com Car Chat > Pontiac > Trans Sport
Old 02-26-2022, 12:08 PM   #1
tinkering
In the 200 Club
tinkering's Avatar
Question 1993 TransSport 3.8L Canister Purge Solenoid Valve Location?
Where can I find the carbon canister purge solenoid valve on my 1993 TransSport 3.8L?
Sounds dumb but I can't find it.
1923 Model T 'Stake' Truck, see in Legends of the Fall
1949 Chevy 3/4 Ton, had 214 ci now 235ci
1959 Dodge Mayfair
1986 Ford Ranger 4 cyl
1993 Pontiac TransSport 3.8
1996 Chevy 3/4 Ton 4x4
1999 Oldsmobile Alero
2004 BMW 330i
tinkering is offline   Reply With Quote
Old 02-26-2022, 10:46 PM   #2
autojoe
Re: 1993 TransSport 3.8L Canister Purge Solenoid Valve Location?
Showing left front engine compartment below horn. Then it is showing left front engine compartment beside all the relays ac relay fan low and high speed relays fuel pump relay then beside those 4 relays shows canister purge solenoid. 3.8 engine.
autojoe is offline   Reply With Quote
The Following User Says Thank You to autojoe For This Useful Post:
tinkering (02-27-2022)
Old 02-26-2022, 10:50 PM   #3
autojoe
Need help circuit testing let me know.
Old 02-27-2022, 01:20 AM   #4
tinkering
In the 200 Club
tinkering's Avatar
Thanks autojoe.
That will help.
1959 Dodge Mayfair
2004 BMW 330i
Old 02-27-2022, 01:30 AM   #5
autojoe
Your welcome.
Old 02-27-2022, 01:37 AM   #6
tinkering
In the 200 Club
tinkering's Avatar
I will get to testing the shift and TCC solenoid circuits in a couple or three days. We can talk over my approach and you can set me straight if needed👍
1959 Dodge Mayfair
2004 BMW 330i
Old 02-27-2022, 04:24 AM   #7
autojoe
Shift and TCC problems? Thought was talking canister purge solenoid problem?
Old 02-27-2022, 11:03 AM   #8
tinkering
In the 200 Club
tinkering's Avatar
Sorry, ya both. I have another thread that includes the Shift Solenoids etc.. I have Quad driver DTCs 26 & 56. I'll send you the link when I get back.
1959 Dodge Mayfair
2004 BMW 330i
Old 02-27-2022, 01:08 PM   #9
autojoe
The newer vehicles have protection built in to the ecm to protect them not sure if yours does but if you replace ecm and there is a short in a component or wiring it will kill the new ecm. The qdm codes are hard to diagnose without specialized equipment. Could check resistance on wiring and components for opens or shorts. Check voltage and current with component on and off.
Old 02-27-2022, 04:19 PM   #10
tinkering
In the 200 Club
tinkering's Avatar
I've been reading in the GM TransSport ssrvice manual. I think I read that the ECM has protection on the Transsport.
I have been working on a plan to test the wiring for feed and ground to components.
Jumper the A (ground) and B terminals on the code connector, then check for grounds at the ECM connectors... I might have that confused? 🤓
Here is the link to my thread on this subject. http://www.automotiveforums.com/vbul....php?t=1154053
I have a new canister purge solenoid (amazon.ca) should I need it.
1959 Dodge Mayfair
2004 BMW 330i
Old 02-28-2022, 04:39 PM   #11
tinkering
In the 200 Club
tinkering's Avatar
I found the canister purge solenoid on the 3.8L. It's at the back of the engine, just back of the intake manifold, and forward of the heater blower motor. I changed it out before with a new unit but no change to the codes.
1959 Dodge Mayfair
2004 BMW 330i
Old 02-28-2022, 10:52 PM   #12
tinkering
In the 200 Club
tinkering's Avatar
Question Re: 1993 TransSport 3.8L Canister Purge Solenoid Valve Location?
How should I check the power supply and ground on the Purge valve solenoid? Is there a 5 volt reference signal, or 12 volts there? Does jumping A and B energize all of the components?
1959 Dodge Mayfair
2004 BMW 330i
Old 03-01-2022, 09:52 PM   #13
Jeffrv
Jeffrv's Avatar
Did you get 2 volumes of the GM shop manual? One large book outlining the mechanical issues, and a thinner book of Drivability and Emissions, which is the one you need now. There should be a section with a logic tree on testing the purge valve. You should have 12V on the pink wire at all times key is turned on. The majority of output devices switch to ground, IE they have power ( 5 or 12V depending on the application) on one side and the PCM switches the ground on and off to control the circuit.
If you dont have the book, PM me and I will send you a scan out of my 1995 manual. Sadly I am not able to post the scans to the forum, but am willing to email them to anyone who needs them.
Jeff
Jeffrv is offline   Reply With Quote
The Following User Says Thank You to Jeffrv For This Useful Post:
tinkering (03-01-2022)
Old 03-01-2022, 10:52 PM   #14
tinkering
In the 200 Club
tinkering's Avatar
Thumbs up Re: 1993 TransSport 3.8L Canister Purge Solenoid Valve Location?
Jeff
That is excellent Jeff. Thanks.
I have both books. I will look up that troubleshoot logic tree in the skinny book. Thanks. Narrowing it down to the skinny book helps lots.
I gave you a Thanks for that.
1959 Dodge Mayfair
2004 BMW 330i
Old 03-02-2022, 05:56 PM   #15
tinkering
In the 200 Club
tinkering's Avatar
Here is a very helpful trouble shooting youtube vid by scannerdanner.
https://youtu.be/kQz3g4HIWgs
1959 Dodge Mayfair
2004 BMW 330i
