2013 AC issue
Daughter's 2013 Fusion is having an A/C problem; a/c compressor clutch not engaging. Pressures are good. Compressor clutch fuse and relay are good.
Is the evaporator temp sensor in a 2013 located in the same place as 2007, et al? Someone with specific knowledge about the 2013 Fusion please reply. Thank you. |
Re: 2013 AC issue
A/C fixed. Wasn't the evap temp sensor(s). Mechanic discovered that the compressor clutch bolt was MISSING!!! He said he's had to install several (QTY?) for this same problem on Fords. Loc-Tite'd the new bolt. A/C working fine. Daughter happy!!!! It's a good day!
