Old 05-06-2016, 10:55 PM
hunter4ever12 hunter4ever12 is offline
Red face New found problem help needed
So I kept getting a IAC code on my 94 k2500 with a 5.7L. So I ended up doing a reset for the sensor. I connected a jumper from terminal a to b on the diagnostic connector. I then turned the key to the on position but didn't start it. Waited 30 sec then unplugged the IAC. I then started the engine and attempted to adjust my idle. According to the procedure I read about your supposed to set the idle down to 600 rpms and then shut the engine off re plug in the sensor etc. But the problem that arises is when I try to do this literally the lowest I can get the rpms is 1600. I turn the idle screw until it damn near is out and I still can't get it any lower... So...something isn't right. Please help with a starting point at least. Thanks.
Old 05-07-2016, 03:15 PM
MikeCStig MikeCStig is offline
Re: New found problem help needed
It sounds like a possibility faulty IAC or maybe a vacuum leak somewhere else.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 05-07-2016, 06:00 PM
Schurkey Schurkey is offline
The IAC is not a sensor.
Does the IAC actually move? Maybe the thing is seized in a high-idle position.
Maybe the wire harness is broken, so the IAC never gets power to adjust the idle speed, and it's currently in a high-idle position.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 05-08-2016, 12:23 AM
I know it's not a sensor... Sorry I miss typed that... Anyway the IAC is literally brand new so I don't think it's faulty because it's doing the same thing as the old one was... Wiring harness is good and doesn't have any cracks or looks like it's been smashed or anything... Although it does appear that the previous owner did replace the plug for the IAC. It's got a new plug wired in. It appears he did it correctly by soldering the wires together then heat shrinking them(although I can't confirm that)
Old 05-08-2016, 01:52 AM
So what happens to the idle speed when you plug the IAC passage with one of those rubber stoppers like a Thexton 368, or similar?
