1998 c230 transmission ?
Drove car up the block and when I went to stop and put the car in park it would not engage and the car kept rolling even though car was shut off. To make things worse car would not start back up and gear shift just moves freely up and down all gears. If Someone with expertise could advise to what the issue may be that would be greatly appreciated,
Thanks Burley El |
Re: 1998 c230 transmission ?
That sounds like a shifter cable problem. It either came disconnected or just snapped. I say this is because it sounds like the car is stuck in drive. Not staying still, car refusing to start, shifter moving without any restriction. I'd start with the shifter cable.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!" -James May, in an old, worn out Lamborghini purchased for less than £10,000. |
