Old 01-07-2016, 01:09 PM   #1
Jonafrog
Cavalier won't turn over, good battery
Hello! I have a 1997 Chevy Cavalier Z24, and my engine won't turn over. I drove it to school yesterday morning and it was running fine, but I tried to start it two hours later and nothing... Sometimes when I turn the key I can sort of hear the pump and everything get ready, but when i put the key to ignition everything quits. Now I know its not the battery because I got a new one at the beginning of the year, and sometimes the lights will come on (sometimes they don't, its very fickle). I tried jump starting it twice but no avail. Also sometimes when i take the key out there is this loud buzzing under dash on the passenger side. The buzzing also came on when I tried to use other electronics in the car like the door lock/unlock switch, and when i opened the glove compartment (there is a light in the glove compartment and it did not come on). So by process of elimination I found it was the door lock relay. Is that the problem? Thank you for taking the time to read this!
Jonafrog is offline   Reply With Quote
Old 01-07-2016, 05:58 PM   #2
maxwedge
A990 racer
Re: Cavalier won't turn over, good battery
Bad cable connections at the battery or ground to frame/engine, this assumes the battery is charged.
Old 01-07-2016, 06:01 PM   #3
brcidd
brcidd's Avatar
Buzzing relays tell the tale.....means you have about 7 volts system voltage- so double check battery is charged- then clean and tighten battery connections as mentioned above.
Put a volt meter to battery first..should read about 12.65 volts fully charged.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 01-07-2016, 06:02 PM   #4
paulfromoh
paulfromoh's Avatar
I would clean the terminals... Seems like a bad ground.
The pump you hear is the fuel pump priming your system so that is normal that it comes on for a few seconds and quits
paulfromoh is offline   Reply With Quote
Old 01-07-2016, 06:29 PM   #5
Jonafrog
Alright, thanks guys I will give that a whirl!
Old 01-07-2016, 06:34 PM   #6
paulfromoh
paulfromoh's Avatar
Good luck... Could also be the coil, but from the rest of what you said it sounds more like bad ground.
