Power door lock - defroster - interior lights, Not working =(
Hi guys, I guess my car is possesed, my interior lights (cealing and map) are not working also the power door lock switch in both doors and keyless entry are not working and the back window defroster all went out at the same time. That was yesterday, I locked my car...then came back..and it wasn't working at all.
I have checked all the fuses, relays, conector and everything look to be working ok. None of the fuses are burned and I tested the keyless lamp relay and it was ok. any idea of what the problem could be? heellpp me please! |
Re: Power door lock - defroster - interior lights, Not working =(
smart entrance control module, assuming you drive a b15 sentra
2005 Aztec Red Spec-V Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs 9.02@ 84.4mph in the 1/8th....... Driver > Car |
have a nice weekend.
01 Nissan Sentra SE 2.0 - 121k |
you too, there should be a fuse under the hood for the room lamp that feeds the power to the module, mine was popped because my module shorted, if all yoru fuses are good it could just be an internal malfunction.... if i can remember ill get you a price on one from work on monday
Oh that would be great! thanks a lot, let me know how much is it. Let me ask you another question, does this module has the frequency for the keyless entry control?....or it's just unplug the bad module, plug the new one?. Thanks a lot once again Nismo_Pilot!
youll have to do a re-learn procedure for your keyfobs, and possibly your actual key. The keyfob relearn is super easy though
thanks! have a nice day
thanks!
Everything is working now!, the lights were working as soon as I connected the new unit, the keyfod started to work after doing the keyfod relearn. Good luck guys! thanks once again nismo_pilot!
I was having this issue on my 2000 Nissan Sentra GXE, checked all the fuses and found the room lamp fuse under the hood fried. Replaced it and everything worked fine. Before jumping to conclusions that it's the Smart entrance contrrol unit, check your fuses. It's not said anywhere but the room lamp fuse under the hood seems to be connected to the room lamp, door locks, and rear window defogger. Hope this helps
