Go Back   Automotive Forums .com Car Chat > Mitsubishi > General Discussion
Old 05-01-2016, 01:39 PM   #1
jprebble
Exclamation Split hose leaking oil driver side interior
I have a Mitsubishi Space which has a thin hose running down the drivers side underneath the carpet, parallel to the fuel door cable, which has a crack in it and is leaking oil. The oil is a clear yellowish colour. Is it brake fluid for the rear brakes? If not any ideas what it is? Would like to try and fix myself if possible...
jprebble is offline   Reply With Quote
Old 05-01-2016, 03:04 PM   #2
MikeCStig
Re: Split hose leaking oil driver side interior
Under the carpet inside the car? That's seems like a peculiar location for a brake line, but brake fluid (like most other types of hydraulic fluid) is a clear yellowish color.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
MikeCStig is offline   Reply With Quote
Old 05-01-2016, 07:35 PM   #3
brcidd
brcidd's Avatar
Do you have a rear wiper?- if in a hose it may be rear wiper washer fluid- which would be easy to fix--just cut out the bad section and splice in new hose.
I've never seen brake lines be rubber inside a car- they are always steel and under the car...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Tags
broken , interior , leak , oil , pipe
