Old 02-14-2008, 11:07 AM   #1
twayne217
1999 chevy lumina Stall and acellerate problems
I have a 1999 chevy lumina with 190,000 miles, 3.1, v6, auto trans. the problem is that it will run great for a while and then start to stall and buck and hestiate. I have had the 02 sensor, egr, ingition mod., plugs, wires, all changed and same problem. I thinking ecm. Does not matter hot or cold it will run then sound like it is missing but will push past for a while, this is at any speed. Any ideas???? I need help this car is driving me crazy and broke!!!
Thanks.
twayne217 is offline   Reply With Quote
Old 02-14-2008, 01:15 PM   #2
jdl
Re: 1999 chevy lumina Stall and acellerate problems
Did you check to see if there were any codes? Some of the national brand autostores will check codes for free.
You didn't say anything about the fuel system, can you check fuel pressure? When was the last time you changed the fuel filter? Make sure there is no pressure on the lines, if you take anything loose.
jdl is offline   Reply With Quote
Old 02-14-2008, 02:10 PM   #3
twayne217
Yes i had the fuel pressure checked and it was at spec and the codes keep jumping around first it was egr then ingition then o2 very confusing.
Old 02-14-2008, 02:48 PM   #4
twayne217
also changed fuel filter.
Old 02-15-2008, 09:08 AM   #5
jdl
What were the code numbers?
Old 02-15-2008, 06:27 PM   #6
j cAT
Thanks.
check all wires going to ground esp. ecm wires and connections repair any damaged wires loose rusted ground lugs fasteners.......this is because codes and failure not consistant
Old 02-16-2008, 01:34 AM   #7
az_emt_911
Hello,
I have a 97 Lumina that does the exact same thing. I had everything checked, come to find out it was the catalytic converter. Have that checked. Any auto shop should be able to do it. Good luck with that.
az_emt_911 is offline   Reply With Quote
Old 02-26-2008, 01:00 PM   #8
liquidfuse
Send a message via Yahoo to liquidfuse
I have a 1998 Lumina with 82k miles, last year the Intake Manifold gasket started to get leaks in it and engine oil was getting inside the radiator.
From what I have heard this is a common problem for a lot of Chevrolet's and the place I took it too says they do these often. I would check your radiator, see if it has oil deposits in the overflow reservoir. When I had it happen to my car, Cylinder 1 and 4 had issues with misfiring so my accerlation lagged, starting was a problem sometimes. Does it have a hard time starting sometimes, not turning over but just engaging period?
It cost me about $700 to get it fixed, tuned up, replaced the gaskets, and flushed the radiator. I hope this is not the issue with yours but if it is be ready to spend some money.
liquidfuse is offline   Reply With Quote
Old 08-20-2009, 06:06 PM   #9
alexxb13
when you turn the key on, but dont start the car, does the fuel pump make a funny noise? I would think it'd be the fuel pump b/c thats what's happening on my '99. Fuel pumps for it run between $300-$400.
alexxb13 is offline   Reply With Quote
Old 08-20-2009, 08:04 PM   #10
maxwedge
A990 racer
Welcome to AF, the pump runs for 3 seconds or so when the key ign is first turned on, if the pump is noisey either the filter is clogged or the pump is going bad. BTW in the future start a new thread this is way too old, thanks.
Old 01-04-2015, 09:16 PM   #11
Nelsonsdad
1. Original intake manifold torques were insufficient from factory. Replace the intake manifold gaskets, and the new torque is doubled to the range of 8-12 ft lb.
2. Condensation buildup in the fuel tank if you don't keep it full will slosh around the wide, shallow tank, be picked up occasionally, throw codes like 0171 lean on one cylinder bank, then clear. Replace fuel filter and if possible drain some gas to check for water. Keeping the tank full is cheap preventive maintenance.
Nelsonsdad is offline   Reply With Quote
Old 01-04-2015, 10:13 PM   #12
Tech II
Nelson, this is an old thread....
