Go Back   Automotive Forums .com Car Chat > GMC > Jimmy
Old 01-24-2005, 06:40 PM   #1
jimp60
97 jimmy key stuck
My key is stuck in the ignition of my 97 jimmy, truck shuts off but won't turn the last click to remove the key any suggestions on what is wrong?
jimp60 is offline   Reply With Quote
Old 01-25-2005, 08:57 PM   #2
Blazer LT
Banned
Blazer LT's Avatar
Re: 97 jimmy key stuck
Turn the key all the way back then pull it out
Blazer LT is offline   Reply With Quote
Old 01-25-2005, 11:48 PM   #3
BlazerLT
AF -Advisor
BlazerLT's Avatar
Re: Re: 97 jimmy key stuck
Disregard this clown, he is now gone.
Make sure your shifter is properly going into park.
BlazerLT is offline   Reply With Quote
Old 01-26-2005, 10:57 AM   #4
BlazinSaddles
Column shifter or floor? There is switch that is activated when the shifter goes into park when this switch is activated it unlocks the key so it will go all the way back and come out. Try wiggling the shifter.
BlazinSaddles is offline   Reply With Quote
Old 01-26-2005, 01:52 PM   #5
bigbadbowtie
I have a 1998 with the exact same issue....console shifted.
I have had the console apart and looked at the switch.. it seems to be working. I checked it with a meter.
On my 98.... there is a small hole on the bottom side of the steering column. If you take a long small diameter screwdriver,stick it in the hole,it will unlock the switch.
I have also noticed when ity sticks.... if I move the sterring wheel all the way up.. it unlocks.
Your 97 is probably similar...
Ray In Bama
78Z 355 roller on the GAS.
bigbadbowtie is offline   Reply With Quote
Old 01-26-2005, 05:02 PM   #6
BlazinSaddles
I read about someone else having the this problem with a console shifter too. Are we seeing a pattern?
Old 01-26-2005, 11:34 PM   #7
jimp60
I tried wiggling shifter I will try screwdriver
Old 01-26-2005, 11:53 PM   #8
BlazerLT
AF -Advisor
BlazerLT's Avatar
Be gentle.
Old 02-03-2005, 10:54 PM   #9
xokayxo
xokayxo's Avatar
Send a message via AIM to xokayxo
i was having the same problem with my '98 and pressing the button on the bottom of the steering column allowed me to turn my key all the way to get it out. but every time i go to take my key out now, i have to press the button! will it do this every time i insert the key from now on? and what is that little button really for?
xokayxo is offline   Reply With Quote
Old 02-03-2005, 11:05 PM   #10
bowtie_pasta
Same exact problem here on my '97 Blazer. Driving me nuts. This seems to be pointing to a problem with the switch. I really want to get this fixed myself without having to take it to the shop.
bowtie_pasta is offline   Reply With Quote
Old 02-05-2005, 07:22 AM   #11
blazee
Problem?
blazee's Avatar
blazee is offline   Reply With Quote
Old 02-05-2005, 07:04 PM   #12
xokayxo
xokayxo's Avatar
brilliant work, bowtie_pasta!
Old 05-22-2011, 10:12 PM   #13
wizard00
I started my 1993 GMC 4x4, as i shifted out of park there was a clunk.
Then there was like a heavy roar as i drove, like i was in 1st gear. i pulled over and put it in park. i tried to shut engine off, but key would not turn off, i drove home, removed ground wire from battery and then popped coil wire off, key still locked in the on, can start truck but cant shut off. all shifting works fine. is there a relay,modole or something that may have blown? i did loose power windows for a few mins but they work fine now.
wizard00 is offline   Reply With Quote
Old 11-29-2014, 09:39 AM   #14
sandralmoncada
97 jimmy key stuck
Thank You for the Intel. This very key/ignition issue is exactly what I've been struggling with. I now have a logical starting point and a renewed hope of a possible easy fix. Well inexpensive fix is more accurate as I will be doing the fixing myself
sandralmoncada is offline   Reply With Quote
