Go Back   Automotive Forums .com Car Chat > Dodge > Caravan | Voyager
Old 07-16-2014, 09:33 AM   #1
jehanny
2008 Town & Country shakes when braking
my T&C strikes again...
Now it shakes when braking at highway speeds (thinking rotors are warped and need changed), but today the brake light, traction control, and ABS lights all come on and stay on when I drive....HELP!
jehanny is offline   Reply With Quote
Old 07-16-2014, 10:00 AM   #2
aleekat
Re: 2008 Town & Country shakes when braking
Probably 2 separate issues. But you definitely need rotors.
Post back, that's what makes Forums Work.
aleekat is offline   Reply With Quote
Old 07-16-2014, 10:06 AM   #3
jehanny
there are no error codes (on odometer). Oh..and to add to the headache, I just replaced the transmission in April and it is downshifting hard when coasting at low speeds and then accelerating (occassionally)
Old 07-16-2014, 10:22 AM   #4
RIP
AF -Advisor
RIP's Avatar
Not positive but believe you need a scanner capable of reading chassis codes on 5th generation 2008-2014 vans in order to read ABS codes. The odo will just give you powertrain codes.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
RIP is offline   Reply With Quote
Old 07-26-2014, 09:35 PM   #5
jehanny
the abs etc. lights are off. Had to replace rotors...and found out sway bar links needed replaced. Now my 05 touring needs the headlamp replaced due to a debris impact to the lens.....
