Go Back   Automotive Forums .com Car Chat > Dodge > Caravan | Voyager
Old 08-01-2005, 07:59 AM   #1
mngixxer
99 voyager door locks keep locking about every 30 seconds
My wifes 99 voyager power door locks keep locking about every 30 seconds. I ahve read a few posts about cleaning the contacts but this didnt do the trick. Any other suggestions?
Thanks,
Scott
mngixxer is offline   Reply With Quote
Old 08-01-2005, 09:45 AM   #2
B33p3r
Every 30 seconds while your driving or even when you're parked and idling?
B33p3r is offline   Reply With Quote
Old 08-01-2005, 09:47 AM   #3
mngixxer
Re: 99 voyager door locks keep locking about every 30 seconds
[quote=B33p3r]It does it all the time; whether its running or sitting not running.QUOTE]
Old 08-02-2005, 09:37 AM   #4
B33p3r
Does EVERY door lock up when this happens?
Old 08-02-2005, 09:39 AM   #5
mngixxer
Yes,all the doors lock. I guess it doesnt happen when your driving, just when the keys are out of the ignition - my wife told me this last night.
Old 07-20-2014, 12:19 PM   #6
lesles
Hi,
Did you solve the Problem?
I have exactly the same Problem with my Voyager 1999
Thanks in advance
Les
lesles is offline   Reply With Quote
Old 07-21-2014, 05:23 PM   #7
RIP
AF -Advisor
RIP's Avatar
I would bet he fixed this 9 years ago soon after he wrote the thread but is now long gone. Check those dates.
Not picking on you personally because many do it but why do folks think they have to tag on to ancient threads. Just start a new thread - simple.
Is your problem cyclic (every XX seconds) like the original post or random such as when turning, stopping, going over bumps, or whenever it likes?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
RIP is offline   Reply With Quote
Old 07-27-2014, 11:50 AM   #8
lesles
Hi RIP
The problem is cyclic. Every 30 - 35 seconds. I use the key fob to lock the door, when I go out of the car. Then every 30 seconds all door will be locked automatically.
This happens also when I am far away from my car.
Thanks for help.
lesles
Old 07-27-2014, 05:25 PM   #9
RIP
AF -Advisor
RIP's Avatar
Cyclic? That leans me towards the BCM. If it were random I'd lean towards a door switch. Try disconnecting the negative battery cable for 5 minutes to reboot the BCM and it's CCD data bus. To save some battery power remove the door lock relay on the fuse panel under the dash. Course then you have to lock manually.
It will cost you a couple hundred but a shop will connect a scan scope and ID the problem. Here's an example with relative to you system info though it's not quite your problem:
http://www.youtube.com/watch?v=UFZqZB1Eds8
This is a 3 part video. I gave you part 2. You can go to YouTube and look at parts 1&3 if you like.
