I have the front end up in the air so I might as well change the broken passenger side outer CV boot. Do I need to take the hub off to get it done, or is it possible to remove the boot, take the joint apart (how?), slip the new boot in place, reconnect the joint halves (how?), then do up the boot clamps? I have changed a couple in the past, and can probably figure it all out but can somebody make life easier on some of this?
Re: Changing Outer CV Boot 1996 Chevy 2500 4x4
...or just save some time and replace the axle assembly. They are probably cheaper then you think, and less time and work. |
| The Following User Says Thank You to gmtech1 For This Useful Post: | ||
tinkering (01-28-2014)
Unbolt axel shaft from rear end and remove outer axle nut. On some you also have to remove sway bar link bolt. Them slide axle out. AS GMteck1 said sometimes better and about as cheap to just install a rebuilt axle shaft.
| The Following User Says Thank You to MT-2500 For This Useful Post: | ||
The parts store had a brand new unit for $152.00. I bought it. When I unbolt the flange at the transfer case, does the unit just come off or is there some kind of keeper there?
After unbolting, it should come loose. It may require a little friendly persuasion from a hammer, but no retainers, just the bolts.
tinkering (01-17-2014)
I elected instead to undo the lower shock bolt and pull the shock out of the way to make room for the drive shaft R+R. The sway bar link looked pretty old and rusty, so I figured I would not risk breaking it off. The shaft replacement went well, thanks.
No many take the time to do that or even say thanks. Good Luck
