Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 01-06-2014, 08:56 PM   #1
rknorr
Send a message via AIM to rknorr
95 S10 TBI (Z motor) intermittent no start
I have a 95 Chevy S10 pickup with the TBI motor, Z engine code, that has
begun to not start on occasion. The engine cranks but does not fire at all
everything else seems normal. This only seems to happen in the morning so
might be cold related. If the truck starts I can drive it all day without any
starting issues. Any ideas where to begin troubleshooting? Any help will be appreciated.
rknorr is offline   Reply With Quote
Old 01-07-2014, 10:03 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: 95 S10 TBI (Z motor) intermittent no start
Check for good spark and fuel pressure and injector pulse and squirt when no start.
Do you have any check engine lights or codes?
MT
Old 01-07-2014, 10:58 AM   #3
rknorr
Sounds reasonable. Just went outside and the truck started right up even though its 43°F out, pretty chilly for around here!! I noticed the voltmeter on the dash seemed like it was reading kind of high, checked with my DVM and its around 15V. Seems kind of high for a truck that drove over a hundred miles yesterday. I would think the battery would be fully charged already.
Old 01-07-2014, 02:04 PM   #4
rhandwor
I would check the grounds alternator bracket,and left cylinder head. If loose will cause all kinds of miscellaneous problems.
rhandwor is offline   Reply With Quote
Old 01-07-2014, 04:36 PM   #5
rknorr
sounds easy enough.
Old 01-07-2014, 04:41 PM   #6
rknorr
Sorry, I didn't notice you asking about codes. There are no check engine light or codes now or when it won't start.
Old 01-08-2014, 11:07 AM   #7
rknorr
Today, no start. Good fuel squirt on start attempts. I'm assuming I have spark since I couldnt get a plug wire off to check. I checked voltages at the two connectors on the coil. With ignition on grey connector had 12 volts on one wire, black connector had nothing on either wire. What next?
Old 01-08-2014, 11:49 AM   #8
rhandwor
I looked at a 1995 4.3L wiring diagram but a W couldn't find a Z. It showed a pnk and wht wire to the coil from the pick up coil. I would use a 12 volt test light find the hot.
Put the test light on the other wire have some one crank the engine the light should blink. This should fire the coil.
Call some parts stores and check if they will test the module free.
Haynes should have a procedure to check the coil.
Old 01-10-2014, 09:46 AM   #9
rknorr
Truck won't start this morning, tested as above, one wire is hot other does not blink.
Old 01-10-2014, 12:52 PM   #10
rhandwor
I think you may have a coil problem but go through the tests for the 4.3L and you will learn a lot and I haven't worked on a lot of this model Chevy. I also have a module testor.
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Tags
problem , starting , tbi
