Old 05-15-2013, 07:01 PM   #1
eswebster
'98 Lumina random no start
So I have a lumina that will randomly not start, wont even try to crank. Everything dies when the key turns off the lock position, but not cranking. Replaced the lock and tumbler. Still does it. When it doesnt start I pull the ignition fuse and it starts right up, EVERY time. Is it the ignition relay? Kinda lost here... any help is appreciated.
eswebster is offline   Reply With Quote
Old 05-15-2013, 08:02 PM   #2
maxwedge
A990 racer
Re: '98 Lumina random no start
When it won't crank do you have 12v to solenoid wire on the starter, when in the crank position? Does the security lite stay on?
Old 05-15-2013, 08:30 PM   #3
eswebster
everything is as dead as a doornail when its in crank position. I pull the ignition fuse and replace it a second later.... go to crank and everything is lit up and the car turns over like there was never a problem.
Old 05-15-2013, 10:27 PM   #4
eswebster
security light is not on.
Old 05-16-2013, 12:29 AM   #5
777stickman
So, are you just pulling the fuse and putting the same one back in?? Also have you checked both battery cables for being clean and tight at both ends?
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
777stickman is offline   Reply With Quote
Old 05-16-2013, 12:40 AM   #6
eswebster
pulling the fuse and putting the same one back in. Something electrical in the ignition system is getting reset by pulling the fuse. Once its reset it turns over beautifully. I have had it stop running a few times while driving, then a minute later without touching anything it turns over again.... but usually it takes a few times with everything going dark when i try to turn it over. One of the times it quit while i was driving i turned the light dial, like turning the lights on had something to do with it. Really odd.
