Old 01-24-2013, 10:20 PM   #1
Chevy327slayer
Roller cam specs
Is there a difference in a roller cam and flattappet cam for the mild and aggressive etc. specs? Or are the specs for them the same if its different what's the roller cam mild specs?
Chevy327slayer is offline   Reply With Quote
Old 01-24-2013, 11:11 PM   #2
silicon212
Confoundingly Lucid
silicon212's Avatar
Send a message via ICQ to silicon212
Re: Roller cam specs
Roller cams generally have a steeper 'ramp', and a longer open-valve duration than what is generally possible for a flat tappet cam.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
silicon212 is offline   Reply With Quote
Old 01-25-2013, 09:08 AM   #3
maxwedge
A990 racer
Duration at .050 is the industry standard regardless of roller or flat tappet, Lift of course is the same. Roller cams can be ground more aggresively yet have more area under the curve. For a more in depth explanation, google "advantages of a roller cam".
