Heater Problems...
I have a '98 ram V6 single cab.
My heater is not working properly. It appears to warm up but doesn't get hot. I mean I will fill slightly warm after a while of driving but not nearly as hot as any other car I have owned. I have recently bought it for a work truck. any help is appreciated. |
Re: Heater Problems...
Cold be a partially stuck open thermostat and or a plugged heater core . Do the heater core hoses get hot? |
I will check the heater core hoses today. |
Well it's running temp is around 170-180°.
Is the thermostat the problem? |
Could be, 160-170F is not normal temperatures...should be 190-200F.
With the engine cold, start the engine, remove the radiator cap and see if coolant is circulating on the cold engine. It should be still with no sign of flow.
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" ![]() "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 ![]() Time to turn so's you don't burn.
I guess the temperature gauge will have to be the main source of info and it indicates the thermostat is faulty.
Upon removal cold, the old thermostat should be open a bit if it's bad. You might look for numbers on it too. Many good folks install a cooler thermostat for summer time and given last year's excessively high temperatures throughout the South, someone may have done that with your truck.
As long as the engine is happy, no Check Engine light, I don't see a problem.
