Go Back   Automotive Forums .com Car Chat > Dodge > Caravan | Voyager
Old 10-22-2012, 06:27 PM   #1
jova2003
Dodge Gran Caravan stops while driving
I have a 2003 Dodge Gran Caravan and while I was driving it stopped on me. It will turn on but once you put it in gear it will turn off and wont turn back on. I have replaced the fuel filter and fuel pump.Any help would be appreciated.
jova2003 is offline   Reply With Quote
Old 10-23-2012, 12:53 AM   #2
RIP
AF -Advisor
RIP's Avatar
Re: Dodge Gran Caravan stops while driving
Work in reverse?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
RIP is offline   Reply With Quote
Old 10-23-2012, 02:46 PM   #3
jova2003
Sometimes it does. Other times it will turn off when I put in reverse.
Old 10-24-2012, 01:32 AM   #4
RIP
AF -Advisor
RIP's Avatar
"It will turn on but once you put it in gear it will turn off and wont turn back on."
When it won't "turn back on" are you saying the engine won't rotate when you try to start or it will rotate but won't start?
I'm leaning toward a torque converter that's locked up but I'm a bit low on transmission knowledge. I'm not sure how you prove that. The only fix for a locked up torque converter when you're not seeing the check engine light and have no codes I have come across on the net is to replace it. That's big bucks. You're going to be better off having a tech diagnose it. Maybe someone with some know how can jump in here and give you that silver bullet.
