Go Back   Automotive Forums .com Car Chat > Chevrolet > Corvette
Corvette
Old 05-15-2012, 05:20 PM   #1
hcm1957
rough idle,low vaccum
I have a rebuilt 350 270 hp engine. Original quadra jet rebuilt and runs rough. Have low vaccum. Help
hcm1957 is offline   Reply With Quote
Old 05-15-2012, 07:45 PM   #2
maxwedge
A990 racer
Re: rough idle,low vaccum
Wow pretty general. vacuum leaks obviously, valves too tight, timing wrong, for starters.
Old 05-15-2012, 07:52 PM   #3
danielsatur
Do a smoke test to pinpoint any vacuum leaks.
danielsatur is offline   Reply With Quote
Old 05-20-2012, 12:22 PM   #4
hcm1957
Timing is on, Lifters are adjusted correctly and no vacuum leaks around intake.All vacuum lines are plugged. still have rough idle and can not adjust idle mixture screws
Old 05-20-2012, 02:35 PM   #5
maxwedge
A990 racer
Compression test next. Or short out one wire at a time see if one cylinder does not change the engine speed or roughness.
Old 05-20-2012, 03:37 PM   #6
DeltaP
My 2 cents: Faulty or incorrect PCV valve or hoses. Poor valve seating. Restricted idle passages. Bad coil. This is in addition to everything else mentioned.
DeltaP is offline   Reply With Quote
Old 05-20-2012, 06:00 PM   #7
hcm1957
Thanks for your 2 cents. All new hoses and pcv, heads where redone and running hei.
Corsa-b running rough and wanting to stall darrensailes Corsa/Barina 2 05-04-2016 01:46 PM
99 4.3 Rough Idle, Low Temp, Bad Gas Mileage dr_lee29 Problem Diagnosis 98 02-03-2016 07:51 PM
P0171 Rough idle uspres2020 Escort 8 04-28-2010 09:06 PM
2001 cherokee rough idle when hot mrrandyz Cherokee 0 03-22-2010 10:54 PM
Help with 97 Villager rough idle dscott1838 Villager 12 05-09-2009 10:34 AM
