Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier
Old 12-28-2011, 12:17 AM   #1
GuyWithCavalier
GuyWithCavalier's Avatar
Exclamation Could ABS Brake System cause noise sliding on snow?
Since it just snowed and no salt or plow, and snow was fluffy and about 2 or 3 inches on the road, I thought I would get the wife to test the brakes with the new (used) snow tires.
When she hit the brakes and turned this way and that,
at about 10 - 20 mph, we got the tires to lock intermittently and slide a bit.
I was thinking hmmm.. even snow tires aren't that great with turns...but then I hear a sound I've never heard before, like a clacking or rattling, maybe even like a pencil-sharpener, as the car is sliding.
The sound seemed to come from the front firewall right at the master-cylinder, and only happened when the car front tires started sliding.
I was wondering if such a surprisingly noisey effect was a result of the ABS brake system not being able to unlock the wheel(s) on snow during the slide.
Does anyone have any experience with ABS brakes and noises,
that might correspond to what I was hearing?
Or could there be something else wrong?
Always Listen to the Experts:
They'll tell you what you CAN'T do, and why.
Then go ahead and do it.
Thats how we got manned flight...
GuyWithCavalier is offline   Reply With Quote
Old 12-28-2011, 02:53 PM   #2
Tech II
Re: Could ABS Brake System cause noise sliding on snow?
That's normal ABS sound....when the ABS is activated due to a wheel slipping, the solenoid(s) rapidly click as they hold and release the fluid to the wheel or wheels that are slipping, similar to someone pumping the brakes, but at a much faster rate......
The Following User Says Thank You to Tech II For This Useful Post:
GuyWithCavalier (12-29-2011)
Old 12-29-2011, 08:10 AM   #3
GuyWithCavalier
I take it that this could prematurely wear out the solenoids if it went on too much?
If the solenoids failed, would the brakes still work?
Old 12-29-2011, 09:00 PM   #4
gmtech1
gmtech1's Avatar
Will not "wear out" solenoids. That is what they're made for. Have never heard of or seen these solenoids wear out. As Tech II stated, this in a normal condition
gmtech1 is offline   Reply With Quote
The Following User Says Thank You to gmtech1 For This Useful Post:
GuyWithCavalier (01-01-2012)
Old 01-01-2012, 01:00 AM   #5
GuyWithCavalier
Okay thats good to know.
I youtube video I looked at indicated that most commonly,
the electronic control module wore out, not the solenoids themselves,
so this seems to relate to that. cheap transistors are still
less reliable than plumbing, I guess.
Old 02-20-2012, 04:47 PM   #6
e40water12
Sounds common like my 01 cavalier.
e40water12 is offline   Reply With Quote
abs braking system jeeponthebeach Cherokee 4 03-21-2005 01:35 AM
Break chatter limilar to ABS brake system kicking in. ironchops 626/Capella/Capella Wagon 0 12-27-2003 09:55 AM
