Go Back   Automotive Forums .com Car Chat > Oldsmobile > Intrigue
Old 11-22-2011, 04:18 PM   #1
budguy007
01 intrigue dash,gas gauge issues
I just bought a 01 Intrigue that the dash lights don't work and the gas gauge stays at fuel when you start the car. It goes to empty when you shut it off.
budguy007 is offline   Reply With Quote
Old 11-22-2011, 08:35 PM   #2
sparcx
Re: 01 intrigue dash,gas gauge issues
gas gauge might be fuel sending unit. Give these two links a shot and see if it matches up with your symptoms:
http://www.automotiveforums.com/vbul...d.php?t=926087
http://oldsmobileforums.com/forums/s...ad.php?t=13447
not sure on the other dash lights issue. Maybe someone else has an idea.
sparcx is offline   Reply With Quote
The Following User Says Thank You to sparcx For This Useful Post:
budguy007 (02-07-2012)
Old 11-22-2011, 09:32 PM   #3
oldblu65
oldblu65's Avatar
The gas gauge symptoms ( always full when switch is on and empty when switch is off ) indicate a break in the circuit feeding the gauge . Could be a wiring issue or something to do with the sender .
" Sometimes I grow so tired "
oldblu65 is offline   Reply With Quote
Old 11-26-2011, 10:30 PM   #4
budguy007
Thanks for the help I figured the dash lights out all five bulbs were blown. Going to try to replace part in fuel sending unit. I hope that fixes it. I dont have any reading on the odometer but it Im not worried about that unless someone has a easy fix.
Old 02-07-2012, 10:20 PM   #5
budguy007
Thanks for the help I actually got a deal on a new sending unit and pump. Replaced them both and now the gauge works fine. I had no idea where to even start to look without some help.
Gas Gauge Issue on Suburban jep5555 Suburban 4 11-13-2008 07:35 PM
Digital Dash gas gauge not reading correctly John T. Regal 8 01-14-2005 01:25 PM
Gas Gauge Issues Stormy62485 Contour 2 07-31-2004 07:40 PM
ABS light and gas gauge issues on my 98 Rodeo mrsmarilyn Rodeo | Passport | MU 2 05-05-2004 05:09 PM
Gas gauge issue? philbee Ranger | Courier 4 02-10-2004 10:02 PM
