Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 02-11-2012, 10:26 AM   #1
Allegretto
Allegretto's Avatar
Send a message via Yahoo to Allegretto
weak heat
2001 bravada 4.3 vortec. it just got antarctic in my town and now i go to turn the heat on and my car does not get as hot as it used to. ive also noticed that the temp gaugebarely moves past 100 degrees even after driving all day. i have turned the heat all the way up but it just gets warm. i think it might be the thermostat stuck open or maybe something to do with the antifreeze. i hope my heater core isnt out i dont want to be out in the cold fixing it. as always any and all info greatly appreciated. thanks in advanced guys.
Allegretto is offline   Reply With Quote
Old 02-11-2012, 01:20 PM   #2
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Re: weak heat
Yup, your thermostat could be stuck open a tiny bit.
With the engine running and as warm as it'll get, feel the upper radiator hose at the radiator.
If it's warm, the thermostat is leaking by. If it's cold, your heater core is drawing out all the available heat, acting as the engine's radiator.
Chris Stewart is offline   Reply With Quote
The Following User Says Thank You to Chris Stewart For This Useful Post:
ericn1300 (02-11-2012)
Old 02-11-2012, 09:31 PM   #3
ericn1300
AF Premium User
ericn1300's Avatar
Re: weak heat
You know it yourself, Allegretto, it's most likely a bad thermostat. A $10 dollar part and easy to replace, but don't forget to get a new radiator cap at the same time. They have about the same life expectancy.
ericn1300 is offline   Reply With Quote
Weak Heat in the Winter AndSum 6 0 01-14-2012 11:55 AM
No heat when not on throtle... COLD... rmwilson Problem Diagnosis 13 12-26-2009 02:09 PM
TIP: Smell When Run Heat on FULL... Intuit Escort 7 11-14-2009 05:11 AM
Weak brakes when cold Allen McCready Econoline 4 11-13-2009 01:08 PM
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 09:49 AM
