Old 01-16-2004, 09:12 PM   #1
bmwtxm0
98 Isuzu Rodeo 2.2L Sludged Engine
I recently bought a 98 Rodeo S with a 2.2 engine. The oil light will flash at highway speeds when the enigne is warmed up. A mechanic at Isuzu told me the engine is sludged from lack of oil changes. He quoted me a rediculous figure to de-sludge the engine. My questions: What is a good cleaner to use? AND: Does anyone know what needs to be done to clean out the oil intake screen? I think this is a procedure a shade-tree mechanic could do, but I have no experience with Isuzu. I usually change my own oil at 2500 - 3000 miles with a good quality synthetic oil....
bmwtxm0 is offline   Reply With Quote
Old 01-16-2004, 09:56 PM   #2
rodeo02
A product that I use & have good results with is @ www.lubecontrol.com Pretty good value at about $30/gallon shipped to your door. Another product that many swear by is @ www.auto-rx.com One of the best sites I've found for oil info/concerns/issues is www.bobistheoilguy.com To clean your oil pump pickup screen, you will have to pull the oil pan. This should not be too bad of a job on a 2wd, 2.2L rodeo. I would definately inspect that screen!! Make sure you change the timing belt every 50Kmi on that 2.2 as well!
G/luck
Joel
rodeo02 is offline   Reply With Quote
Old 01-30-2012, 05:16 PM   #3
2001IsuzuRodeo2.2L
Re: 98 Isuzu Rodeo 2.2L Sludged Engine
Ahhh .... welcome to the World of the Isuzu 2.2L
I have a 2001 Rodeo 2.2L .... and ive been ALL OVER these threads. Below I'll tell you all I've done lately (I went from having never done ANYTHING on a car... to becoming somewhat my own shadetree mechanic through parts on eBay and help on this forum).
If I may recommend... get some SEAFOAM. That stuff worked WONDERS for me.
$10 at WallyWorld (walmart) .... 1/4 bottle in the gas tank. 1/4 bottle in the crankcase (a couple days before oil change) and 1/2 bottle run through the PCV valve.
That stuff made an INSTANT improvement in the way my car runs... and even cleared an obd code or two. (O2 sensor no longer comes up in obd codes, and car runs MUCH smoother at idle and while driving).
As of now... I had to deal with 8 obd codes. I got rid of all of em but one by doing the following:
spark plugs
spark plug wires
valve cover gasket
camshaft position sensor
fuel sending unit (dropping the fuel tank was ALL KINDS of fun)
air filter
fuel filter
alternator
and now I have codes P0301 and P0128 still showing
Ordered a coil pack from eBay ($30) hoping that will help or eliminate P0301 (misfire cylinder 1)
Ordered a new thermostat hoping that will help or eliminate P0128
Back to your question though... SEAFOAM. SEAFOAM. SEAFOAM.
2001IsuzuRodeo2.2L is offline   Reply With Quote
Old 01-30-2012, 10:28 PM   #4
Cat Fuzz
Ok, 8 year old thread, but here is my opinion anyway. If the engine is significantly sludged, no amount of any chemical is going to help. Time to replace the engine. You'll never get the gunk out and you will probably seize the engine by loosening up all the crud at once.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Cat Fuzz is offline   Reply With Quote
96 Toy Camry LE 2.2L 5S-FE parts needed Maulana Classifieds 0 03-18-2010 01:17 AM
Replacing the rear main oil seal on 96 Isuzu Rodeo 3.2L 96IsuzuRodeo Rodeo | Passport | MU 5 05-18-2006 06:30 AM
is 1994 2.2l cav engine ok to switch parts with 98 2.2l engine? CFVarsity Cavalier 5 08-14-2005 03:32 PM
1996 Isuzu Rodeo 3.2L V6 4x4--New Owner Crystal3477 Rodeo | Passport | MU 7 10-11-2004 09:49 PM
1996 Isuzu Rodeo 3.2L EGR Valve Location oiram Rodeo | Passport | MU 1 12-14-2003 11:31 AM
