96, shudder at 40-45 MPH?
Hello, been long time since I posted on here, but anyway. I have a 96, 3.8 155K. At around 40 MPH, there is a shudder/vibration from the front end. I took off the tires and inspected the suspendtion, CV rubber boots, and all seems to be OK. Trans oil is OK. Is the trans ready to go? or any help from anyone that may help me look into this problem. Thanks.
![]() Join Date: Sep 2004
Re: 96, shudder at 40-45 MPH?
Is there a check engine light coming on?......like from a misfire?
Clogged EGR ports could be a cause of misfire. To verify, remove and plug the vaccum line that goes to the top of the EGR valve. Start motor and drive the vehicle. If the problem does NOT happen, then the problem is likely the EGR system. If the problem still happens, then the problem is not likely the EGR system. Reconnect the vaccum line to the top of the EGR valve. This test will cause the Check Engine Light (CEL) to come on because you have disabled the EGR valve from being able to open during this test.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
No CEL on, but I will pull the codes to see if any are there. I will try the test with the EGR system. Thanks.
I also have a '96. Is the shudder intermittent? I've had one from my transmission that occurs when the TCC locks up. Watch the tachometer.... if it drops during (or just after) the shudder, then it's a good chance your TCC chattering during lockup.
I started seeing this at around 60k miles. It has done it ever since, even after replacing the transmission with a rebuilt one. I've had trouble getting mine fixed, so if this is the problem and you're able to get it repaired, I'd like to know the ultimate cause. |
I googled torque converter shudder, and it sounds like what my promblem is. About the only thing I can do now is to change the trans fluid. The article on google mentions when have this shudder, replacing the trans may not cure it.I'm not going to replace the trans do to its age, going on 16 years old.
#6 | ||
1995 Windstar 3.8L 2001 Dodge Ram 2500 5.9L Gas Burner 1986 VW Golf 1.6L Diesel |
#7 | |
Uzzo2, thanks for the info. I can not imagine that the coil pac can do something like that. This shudder I have can be more like a short shudder/ trans shifting alittle hard? Wiswind reconmended the EGR, I have not played around with anything yet. I would not have the trans replaced do to 16 years old now.
#8 | ||
http://www.automotiveforums.com/vbul...d.php?t=711481 http://www.automotiveforums.com/vbul...d.php?t=717786 http://www.automotiveforums.com/vbul...d.php?t=900292 None of this may apply to you at all, I've heard that the 95's were a beast all of their own. I figured that it wouldn't hurt to post it though just in case, hope it helps!
#9 | |
OK, what I did so far was disconnect the vac line to the EGR valve. And it seems that the problem/shutter is still there. Its hard to look for when I am waiting for the shutter. I had the vac line off for 2 days,and drove all over the place. I reconnected the EGR vac line and i will still look for the shutter. I did not have the CEL light turn on with the vac line disconnected, and no codes stored. I want to know if anyone cleaned out the EGR ports a second time?I have done it and it was along time ago. Im not to sure what to do next.
#10 | |
Well this is was has happened so far. Friday morning started the the van and right away I smelled a burning/burnt smell. It was 5 above out side and the van was cold. Drove it to work and the smell lasted about 15 minutes. Then, I drove home and still right away the burnt smell. Then the tach jumped up and down, the oil,battery,park lights came on. The tach was on zero but I can still rev the engine. Then the engine died and the van bucked to a stop. No restart, battery dead. Towed home. Replaced the battery and she came to life. Still have that burnt/burning smell even outside the van. Drove the van, and it seemed to labor when at idle and driving. I checked the trans fluid and did not smell burnt. I think maybe its the torque converter? or the cat.converter is going bad?So now Im thinking its time to donate her and part with her. I dont want to put any money into it.
#11 | |
Battery died?......How is the alternator?, sometimes they go out together......battery dies, pulling a LOT of current and burning out alternator.
Or.....Alternator dies and battery discharges. Anyhow, I would verify that the battery is getting charged....... I don't see the problems you mention causing the battery to suddenly die or cause some sudden current draw that kills the electrical system.
#12 | |
There is no vibration at all during accelerating. I will check to see if the alternator is charging.
#13 | |
I checked the alternator for charging. The voltage with van off from the battery is 12.5 volts. Started van and went up to 13.5 to 14 and came down to 12.5. Turned on the head lights and jumped up to 14.5 and the came down. After about a minute of running the alternator housing got very hot, almost enough to sizzle spit. And it smelled with that burnt smell. Alt. bad? most likely.
