Go Back   Automotive Forums .com Car Chat > Oldsmobile > Silhouette
Old 12-19-2011, 09:09 AM   #1
EDDIE138301
ASAP! Which way to move the belt tensioner when removing!
Okay experts! need quick reply for this 2000 oldsmobile belt tensioner removal.
I took my rachet and pulled upwards. It moves a little but not enough to get the belt off. What am I doing wrong? I pull the other direction, nothing. Help!!!!!!!!!!!!!!!!!
EDDIE138301 is offline   Reply With Quote
Old 12-19-2011, 09:19 AM   #2
maxwedge
A990 racer
Re: ASAP! Which way to move the belt tensioner when removing!
Possible the tensioner is binding, sometimes I really have to give it a yank.
Old 12-19-2011, 09:27 AM   #3
EDDIE138301
So I am moving in the right direction? I am pulling up on it. If I was going the other direction, I would not get any movement out of it at all, correct?
Old 12-19-2011, 10:21 PM   #4
oldblu65
oldblu65's Avatar
I took my ratchet and pulled upwards. It moves a little but not enough to get the belt off. What am I doing wrong? I pull the other direction, nothing. Help!!!!!!!!!!!!!!!!!
Are using just the ratchet ? The idler assembly can sometimes be quite difficult to pull unless you use some sort of extension on the ratchet giving you more leverage . A pipe ( that fits over the ratchet handle ) will help immensely but be very careful that it doesn't slip off and hurt you or damage your vehicle . The additional leverage will be immediately evident ! It's a good idea to have someone help you so one can pull on the ratchet and hold the tension while the other removes ( or installs ) the belt . Good luck !
" Sometimes I grow so tired "
oldblu65 is offline   Reply With Quote
Old 12-20-2011, 02:17 AM   #5
DeltaP
I'd say rotating it away from the belt would be the right diriection! They make a tool for that. It gives the proper leverage.
DeltaP is offline   Reply With Quote
04 ss , Heater hose through the belt tensioner? Jimsi01 Monte Carlo 0 02-11-2009 07:46 PM
Where is the Belt tensioner goon13642 Alero 2 04-10-2008 12:32 AM
anyone know how to remove the Belt Tensioner Assembly ford460bigblock Cavalier 2 12-31-2005 11:47 AM
How do I replace the belt tensioner gradyn S-10 1 10-14-2004 10:10 PM
How to replace the belt tensioner idler/pulley on '89 Lesabre the_doctor LeSabre 1 09-28-2004 08:19 AM
