Go Back   Automotive Forums .com Car Chat > Toyota > 4Runner/GX470
Old 12-13-2011, 02:55 PM   #1
Cbpcop
Cbpcop's Avatar
Cool O2 sensor replacement question
Stats: 98 4runner, 4 cyl, automatic, 2wd, 150,000 miles.
Question: what kind of mileage impact can the O2 sensor(s)have on the vehicle if one or both are bad. Neither has ever been changed. Nucklehead 1 (toyota service guy) says save your $ - just not necessary to change 'em. Nucklehead 2 (auto parts store guy) says Change 'em - could cause as much as 2 mpg loss or even more.
Also, what other kind of performance losses can they cause if they have gone bad?
Thanks in advance for the input.
Cbpcop is offline   Reply With Quote
Old 12-13-2011, 03:58 PM   #2
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Re: O2 sensor replacement question
I don't think they have a substantial decrease in mileage if the front one is bad. Even though you would think so, I didn't notice a difference (although I didn't leave it in for long after I had the trouble code). The rear sensor will not affect performance since it is only a catalytic convertor efficiency indicator.
I wouldn't change them unless you get a DTC (Check Engine Light) indicating one or the other are bad. You may loose some power if the front one is bad. Note that if you receive a trouble code indicating poor catalyst efficiency, it is most likely a bad rear sensor, not the cat convertor.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 12-21-2011, 10:30 PM   #3
fourwd1
AF -Advisor
fourwd1's Avatar
Yeah, either one being bad can cause a noticeable mpg loss, the EFI isn't running in it's most efficient mode.
But if any are bad it should also cause a error code and trip the engine light.
Big question, what made you take it to the shop to begin with?
If just lower mpg, could be other things.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
fourwd1 is offline   Reply With Quote
Question: 2003 with W8-sensor problem? loocha '97+ 5 09-01-2009 10:00 PM
96 Civic HX o2 Sensor Replacement.... shvd98z24 '96-'00 Civic 3 03-30-2009 09:49 PM
Replacing manual lever position sensor aka: transmission range sensor digglett21 Thunderbird 1 07-17-2008 07:18 PM
Oxygen sensor replacement-question please... sprat Cavalier 10 03-07-2006 09:02 AM
