Go Back   Automotive Forums .com Car Chat > Chevrolet > Venture
Old 11-20-2011, 10:16 AM   #1
dakota1205
2002 venture misfire/white smoke
I have a 2002 venture, ~196K miles on it, and is in good shape. My issue is i got a P0301 (cyl. 1 misfire detected) along with a P0131 (already took care of it). I checked under hood for loose wires, etc. and cleared codes and see if it will happen again. Well it did, this time it started loosing some power, white smoke coming out exaust pipe, and started hesitating. Got it towed home, checked oil dipstick, has some hint of antifreeze in it, the throttle body also has what looks like oil/antifreeze in it. I started tearing it down and thought I should see if I can get some input on what it might be. Pulled out #1 plug, it looks a little wet, I did a new plug and wire job NOV. 07 at 135K. . I replaced the intake gaskets JAN. 09 at154K.(used FELPRO brand). I'm your do it your selfer mechanic, if I have the tools (or I can rent them). Any input on what I might be getting into would be greatly appreciated.
dakota1205 is offline   Reply With Quote
Old 11-20-2011, 10:27 AM   #2
maxwedge
A990 racer
Re: 2002 venture misfire/white smoke
Intake gaskets or a head gasket. Get the intake off and look at the intake gaskets, if ok pull the suspect cyl. head.
Old 11-21-2011, 08:42 AM   #3
sverker
It sounds to me like typical symptoms for a blown head gasket, or possible cracked head but let's not hope for that.
sverker is offline   Reply With Quote
Old 11-22-2011, 01:55 PM   #4
fanta2
GM Fan, but waning a bit.
I agree - been there, done that.
fanta2 is offline   Reply With Quote
Old 11-22-2011, 05:36 PM   #5
gmtech1
gmtech1's Avatar
I agree with the others, sounds like head gasket to me.
gmtech1 is offline   Reply With Quote
misfire on cylinder #2, white smoke, overheating, HELP?! jeremywitt Durango 5 06-16-2011 09:43 PM
White Smoke Out The Exhaust aduttonater Sephia 0 03-15-2010 06:29 PM
Misfire and bluish white smoke from Engine at startup jahworks123 Tahoe 6 08-19-2006 01:31 AM
Misfire Codes, White smoke and whirring sound jrehm Prism 4 12-24-2005 07:02 PM
2002 Engine Sounds like a Diesel and Blows White Smoke when Cold tony17112acst TrailBlazer | Trailblazer EXT 6 10-10-2004 11:55 PM
