Go Back   Automotive Forums .com Car Chat > Buick > Skylark
Old 01-05-2012, 04:24 PM   #1
HeWhoKillz
buick stalling
I have an 89 with the 4 cylinder engine. When its cold, on a cold start, my car will start really slow and rough. It will run but it sputters a little bit. Like its missing. There is a lack of power. If you go ahead and drive it runs like that for about 20 seconds and then the power returns and it drives just fine. Any thoughts? This only happens when its cold. Once it warms up it is fine. It will start fine with no problem after that.
HeWhoKillz is offline   Reply With Quote
Old 01-05-2012, 05:44 PM   #2
shorod
SHO No Mo
shorod's Avatar
Re: buick stalling
That 2.5L 4-tech has a distributor, correct? Have you checked the distributor cap when cold for any signs of moisture? When's the last time you've performed a tune up on that car? Even back in '89 GM had some reasonably good diagnostics and supported datastream. If you have a professional GM OBD-I scan tool you may be able to glean some information from monitoring sensor values when cold versus when the power returns.
-Rod
Old 01-10-2012, 10:59 AM   #3
jdmccright
The RustBuster
jdmccright's Avatar
Re: buick stalling
I am going to guess that you have a Buick Skylark since that's the only Buick that had a 4-cylinder engine in it. But you can help by telling us if it is the old throttle body injected 2.5L or the newer port fuel injected Quad-4 2.3L.
I'd first check for a vacuum leak by spraying the TB and vacuum lines down with carb cleaner (probably needs it anyways) while the engine is runningand warm but not hot. When you squirt around the carb base and hoses and the engine stumbles, you've found a leak. After that check the coolant temperature sensor, the IAC (idle air control) valve, and the EGR (exhaust gas recirculation) valve, if equipped. These are common problems when starting cold.
Next, any lingering smoke from the tailpipe when it is cold? Does it smell sweet? Like gas? Like burning oil? With it missing I'd guess it smells like unburned gas. If so, I'd turn to the spark plugs and remove each of them and check for oil fouling or wetness due to fuel or water after the car has sat overnight. A fouled plug can't create the needed spark, so the oil/fuel/coolant leak needs to be fixed.
Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Last edited by jdmccright; 01-10-2012 at 11:03 AM. Reason: revised from carb to FI
jdmccright is offline   Reply With Quote
91 Century Stalls Out smilen2894 Century 1 10-01-2010 03:43 PM
89 buick stalls on takeoff musclecarfan6 Century 2 03-24-2008 10:37 AM
97 Buick Stalling mmclean27 LeSabre 27 05-17-2007 11:01 PM
94 Buick stalls when raising windows... buck812 LeSabre 8 03-10-2007 03:41 PM
buick stalls musclecarfan6 Century 0 08-02-2006 08:28 AM
