milky oil on transmission dipstick?
So i got a second hand radiator because the old one was bad. put it in than after about 15k the car just wouldent go forward it goes forward a bit but barley i checked the dipstick and it has a bit of oil on it and its milky white did the radiator coolant leak into the the transmission cooling thing? and is my transmission ruined now or what?
Re: milky oil on transmission dipstick?
sounds like your right,if you get real lucky maybe flushing out the trans real good when your done will salvage the trans.it depends on how long the anti freeze was in the trans,the clutches,seals may have been ruined how old & miles on trans
Live For Today Yesterday is gone, Tomorrows are'nt promised. |
| The Following 2 Users Say Thank You to inafogg For This Useful Post: | ||
jon@af (08-09-2011),
vegetables (08-08-2011)
not sure this car was last registered in 2008 my dad got it off a mechanic who had it sitting under a tree but the engine and gearbox seem really good as if someone has rebuilt it anyway turns out it wasnt water and my radiator doesnt leak water into the oil cooler took 3 litres to get the tran full goes good now
good to hear you got it
| The Following User Says Thank You to inafogg For This Useful Post: | ||
vegetables (08-09-2011)
nope it was running good, But i only took it for a small test run but i still have the problem!! ok if i dont accelerate at all the car will drive on its own at about 3km/h but than if i accelerate it feels as if it gets into gear than itll take off than it will just stop and go along on its own... and rpms rise but it doesn't go anywhere if i rev it up a bit it will reach 40km but i can still hear the rpms rising and the car just doesnt seem to want to go into gear than when it does seem to get into gear it will just stop as if its in neutral and rpms rise and it will only go up to 40km if i rev it up a bit. any clue what the problem is??? i noticed it did this from when i first got it going but it wasnt no way near as a bad as it is now. id just play arround with the throttle and itd get into gear and easily reach 130km but now its just fukeddd
what are we working on???year miles ect.
toyota corona 1986 st141 150k on it someone said it could be a filter,modulator, or the tv cable i dont think its the tranny cause it was having trouble getting into the top gear and i had to play with the throttle to get it to go into top gear but once in top gear it whent just fine. also i noticed when it whent bad i can hear this airy whistling noise somewhere near the engine could that be a bad modulator?
clutches in transmission do not fair well when anti-freeze ,,,AND water ,,are in there ,,,,transmission is most likely going to fail,,,water destroys clutch linings,,,usually very quickly
read my post i THOUGHT there was water in there but there wasn't. i looked at the dipstick in daylight and its pink
no same problem. not having trouble finding drive with the shift leaver my cable is not broken and doesnt need adjusting or anything. i'll have a look at my tv cable and change my filter and hope my tranny isnt shot. Last edited by vegetables; 08-11-2011 at 12:33 AM. |
let us know
vegetables (08-18-2011)
when't to an auto shop to order a new filter and the dude said that my car doesn't have a filter anyway i found out some have a strainer which mine must have can i take this out and atleast clean it or what? also found a used tranny for only 150 which i will be buying if my tranny still doesn't work after i drop the pan and change the fluid. and is that a good price for a used tranny? and how much would a rebuilt/new one cost?
