Go Back   Automotive Forums .com Car Chat > Chevrolet > Venture
Old 07-17-2011, 08:01 PM   #1
venturenot
oxegyn sensor reads 0 on OBDII scanner
Sometimes when I am at highway speed (55 to 65mph) when going down a hill, if I take my foot off the gas pedal my scanner shows my upstream o2 sensor at 0 and my LT & ST fuel trim at 0. This does not change until I put my foot on the gas and then the O2 sensor starts switching normally and fuel trims begin to change.
Is my O2 Sensor about to go bad? I just changed my throttle position sensor, could this have something to do with the problem?
venturenot is offline   Reply With Quote
Old 07-17-2011, 10:13 PM   #2
lesterl
lesterl's Avatar
Re: oxegyn sensor reads 0 on OBDII scanner
Hows your gas mileage?
Any codes pop up?
LT fuel trims staing pretty low (close to 0)?
The closer to 0 you can stay the better it isnt adding/ subtracting fuel to the mix.
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
lesterl is offline   Reply With Quote
Old 07-17-2011, 10:25 PM   #3
venturenot
Any codes pop up?
Not bad, and not the best it has been
No
They are at zero along with the O2 sensor under the conditions I have described, otherwise long term fluctuates between - 1 and -6
Yes, but maybe it is staying at 0 because O2 sensor is not giving any feedback.
Old 07-17-2011, 11:05 PM   #4
lesterl
lesterl's Avatar
Well if it is going negative it is subtracting fuel from the mix (leaning it out), perhaps you have a minor fuel leak or something? What is your fuel pressures like?
OBDII Scanner Tool mooseketer Avalon/Pronard 2 03-17-2011 12:45 PM
OBDII scanner Will12 '97+ 0 03-16-2006 02:42 PM
OBDII scanners westsider Blazer 27 02-28-2005 09:16 PM
OBDII scanners westsider Engineering/Technical 2 02-06-2005 09:15 AM
